Help! an engine bearing on it's way out? :(
This clip: http://www.youtube.com/watch?v=sVMUKilwk98
shows my engine in idle, listen closely you can hear what sounds like a unhealthy bearing noise thats separate from the normal loud injector ticking, coming from the timing chain side of the engine. Notice at the end of the clip when i move the camera towards to middle of the engine, the noise quietens. In person, its quite allot more audible. Anyone have a similar sound on their car? Or have any opinions on what it might be? I hope it isnt anything thats going to cost a heap to fix :( |
turn it around and kiss its *** goodbye :)
j/k - it almost sounds like a diesel on my computer. Could very well be. Throw some Lucas oil treatment in and see if it makes a difference. Does the sound get progressively worse with higher rpm's/? Does the sound get "faster"? |
j/k - it almost sounds like a diesel on my computer. Could very well be. Throw some Lucas oil treatment in and see if it makes a difference. Does the sound get progressively worse with higher rpm's/? Does the sound get "faster"? Hmm not that i've really noticed, when revving it at idle, the increased rpm sort of drowns out the bearing noise. Ill give it a try though and see what i can hear. About it sounding like a diesel, i always though that was a bit of a loose timing chain, i might need to replace the tensioner. Thanks for the help so far! |
Is your car 5speed? Sounds like transmission differential bearings to me
I wouldn't panic just yet. It could just be your AC/Alternator belt tensioner pulley or your timing chain tensioner. Isolate your belts and go from there.
try to take another video from underneath the car with the plastic under-tray removed. also, put your ear to the handle of a screwdriver and probe around the oil pan and block. you should be able to isolate it. to me it does indeed sound like a bearing, but the audio is a bit muffled.
Originally Posted by maximus_pr
usually the a/c tensioner make a whining noise when bad another symptom is burnt rubber smell fom belt also lights flickering as alternator not working at 100% capacity
Re: Help! an engine bearing on it's way out? :(
Seems my '99 maxima (auto trans) is making the same sound... anyone come up with what that noise is? :noes:
99% sure that's timing chain rattle. Bearing noise is more of a knocking sound than rattling like that. Replace the tensioner and you should be good to go.
| All times are GMT -7. The time now is 09:52 PM. |
