Alarm Remote / Corners (near headlights) don't work
Has anyone ever had this problem before? All of a sudden, my remote for my car stopped working and my corner lights stopped working. Help
Try reprogramming the KEY FOB .. it should work..
as in terms of the corner lights... check fuse or bulbs ( never know ) |
I tried reprogramming. When I took the key in and out of the ignition, my lights don't even blink.
Did you do a the corner light mod? If so, you harness or connector might have melted. I had the same thing happen to me a while back. As far as your Alarm, you should follow the owner's manual to reprogram. There is a sequence that you need to follow. If that doesn't work, check the battery in your remote.
I finally got the remote to work. I pulled out just about every fuse and plugged them back in. After that it worked. I guess one of them was loose. Still trying to get my corner lights working. I took both of them out to check for any melting and everything was fine.
Did you check you main fuses in the engine bay? Relays maybe?
| All times are GMT -7. The time now is 10:05 PM. |
