Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Speed gov'nor?. (https://maxima.org/forums/4th-generation-maxima-1995-1999/402912-speed-govnor.html)
maxlinegtr Jul 20, 2007 01:03 PM
Speed gov'nor?.
I have a 97 GXE auto converted to 5 speed. all 5 speed parts are swapped from a 97 SE model (including the ECU). How and why does my fuel still cuts off before 120MPH?....let me know....thanx
devilz05 Jul 20, 2007 01:09 PM
So you dont kill yourself...
(sorry I couldnt be more helpful)
darklegend06 Jul 20, 2007 01:30 PM
I think the wiring was different between the SE and GXE for the speed thing.
SOmeone correct me if I'm wrong.
Also when do you go 120+?
pmohr Jul 20, 2007 03:37 PM
s/gov'nor/gov'na
Anyway, have you tried interrupting the VSS signal to the ECU and see if it still governs your top speed? FTR, my '95 SE has none, and I can't seem to find any definitive source of what does and doesn't have a speed limiter (re: trim/year)
pmohr Jul 20, 2007 04:10 PM
Wiring should be constant across all trim levels. Here's from the 97 FSM:
http://hackzbox.homeip.net/~pmohr/pi...do-diag-97.bmp
And just for reference, it's hooked up the exact same as the one on my '95:
http://hackzbox.homeip.net/~pmohr/pi...do-diag-95.bmp
All speedo circuits are the same, it's completely ECU dependant. Are you absolutely sure (OP) that it's a 5MT ECU?
maxlinegtr Jul 21, 2007 03:28 PM
Let me check it...I would actually think once you change the ECU from a GXE to a SE 5 speed it would comply max out instead of cutting out....my other max born an SE does not have that issue. I wonder if there is any other source that might give me fuel cut off right at 120.
