Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Can someone tell me what's wrong with my car?? (https://maxima.org/forums/4th-generation-maxima-1995-1999/41970-can-someone-tell-me-whats-wrong-my-car.html)
SkyXRacer Jul 29, 2001 09:06 PM
I have a 97 auto with 125k on it. When I have my car in park and the car started the rpm metter starts bobbing up and down between 500 and 1000 rpms. Sometimes it'll go under 500 and the engine will almost stall but it doesn't stall it jumps back to 700 rpms and start going crazy again.
What could be wrong? Could it be bad spark plugs?
hockeyghst Jul 29, 2001 09:34 PM
i had that problem last week in a parking lot it did it in park and in reverse i just put it in park agian and reved up the engine a little which didnt do anyhting then i jsut put it into reverse then into drive drove liek 1/4 th of a mile and it was fine.......does ur do it all the tiem or does it stop then start up again
ionicmax Jul 29, 2001 09:41 PM
Have you done the 60K mile service yet?
It sounds to me that your car may need a tune up. If you haven't done the 60K mile service yet (spark plugs, filters, ect) then you might need to do this now.
Good luck!
tifosiv122 Jul 29, 2001 09:58 PM
Re: Have you done the 60K mile service yet?
Good luck!
Yeah, it needs a tune up, your right.
Erik
SkyXRacer Jul 30, 2001 12:00 PM
I got the 60k tune up at around 70k. I probably do need a tune up now. How much do you guys pay for 60k tune up. It cost me around $400.
NeverEnough Jul 30, 2001 01:46 PM
could be a vacuum leak, too.
I've seen similar problems in my friends' cars and trucks, only to come to find out that the problem all along was just a disconnected vaccum hose. Even if you are not mechanically inclined at all, you can still look around at all the hose underneath the hood and make sure they are all attached to something, and look for tears/holes in the hoses while you are at it. You do need the tune up, though, so do that anyway, but this may keep you from being frustrated the next time you try to drive. Hope this has helped.
-Lee
SkyXRacer Jul 30, 2001 06:08 PM
Re: could be a vacuum leak, too.
cool thanx
