Ok here's the deal.. I just passed 60k on my 97'SE.. So I decide to do the necessary tune up... I changed the plugs, Flush and Drained the tranny, Radiator, A/C and crap loads of other things.. Car running great at this point..
I went to a small meet us Atlanta people held. And a few of them had intakes. I always wanted one, and had the money at the time.. So I purchased one and after I put it on, a day later my car starts to idol a lot different.. It idoled at about 7hundred before I changed this. Now it idols at 5 or 6 hundred.. That's not really the problem, Its when I come to a fast stop the car almost stalls out. A few times it has. Is this normal with aftermarket intakes? Am I suppose to reset the computer,and if so how would I do this? This is getting on my nerves i'm tempted to put the stock intake on. Has this happend to anyone else, Or does anyone have any suggestions on what is going on here and how to fix it? Thanks in advance. NeL |
Check for an intake air leak. Make sure everything is on tight. Also check to see if your MAFS is plugged in.
LIke Billy Idol?
It's spelled I-D-L-E |
Originally posted by medicsonic Check for an intake air leak. Make sure everything is on tight. Also check to see if your MAFS is plugged in. |
Hmm, attaching that should have worked. Reset the ECU. http://vbxmaxima.8m.com/ecu.html , and then report the results.
Thanks alot man! Your a huge help.. Hopefully this should work.. I'll post up tomorrow and let you know..
Later, NeL |
It sounds like you damaged your MAFS {Mass Air Flow Sensor} when you installed your intake. Resetting your ECU is not going to make any difference because your ECU reprograms it's self when new mods are added.
Originally posted by emax95 It sounds like you damaged your MAFS {Mass Air Flow Sensor} when you installed your intake. Resetting your ECU is not going to make any difference because your ECU reprograms it's self when new mods are added. I dunno what is going on with it.. |
© 2024 MH Sub I, LLC dba Internet Brands
