Koni's...how to adjust the rear?
I lost the instruction sheet. I want to adjust the rear, see if I can adjust it lower. My friend and I did the install of the Koni's, but I forgot how to adjust the rear. Anyone? Thanks.
Re: Koni's...how to adjust the rear?
Originally posted by Cumalot I lost the instruction sheet. I want to adjust the rear, see if I can adjust it lower. My friend and I did the install of the Koni's, but I forgot how to adjust the rear. Anyone? Thanks. that's a good ?.... by the way...do your rears squeak sometimes...i just noticed that my passenger side does a little.....WTF? |
Re: Re: Koni's...how to adjust the rear?
Originally posted by pawn that's a good ?.... by the way...do your rears squeak sometimes...i just noticed that my passenger side does a little.....WTF? |
Originally posted by Cumalot I lost the instruction sheet. I want to adjust the rear, see if I can adjust it lower. My friend and I did the install of the Koni's, but I forgot how to adjust the rear. Anyone? Thanks. The height is adjusted by where the cup that holds the spring is placed. The strut has two settings, a higher and a lower. Mine came set for the lower out of the box... The rebound rate is adjusted by compressing the strut and turning it the direction indicated on the strut. In either case you have to take the struts and springs off the car. |
Originally posted by ejj5875 What do you want to adjust? The height or the rebound rate? The height is adjusted by where the cup that holds the spring is placed. The strut has two settings, a higher and a lower. Mine came set for the lower out of the box... The rebound rate is adjusted by compressing the strut and turning it the direction indicated on the strut. In either case you have to take the struts and springs off the car. |
Re: Re: Re: Koni's...how to adjust the rear?
Originally posted by Cumalot Hm...if that's the case, I think mine's already set at the low setting. I called up my friend and he told me that it's already at the low setting. I guess I can't do anything about the rear, it's more the Sprint's than the Koni's. |
Re: Re: Re: Re: Koni's...how to adjust the rear?
Originally posted by ejj5875 Yeah, you're kinda stuck with the height. Without buying new springs your only real option would be cutting the sprints. Not a great idea if you ask me. |
| All times are GMT -7. The time now is 09:23 AM. |
