Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   weird clacking noise coming from the front driver's side (https://maxima.org/forums/4th-generation-maxima-1995-1999/537949-weird-clacking-noise-coming-front-drivers-side.html)
vqmaxman Sep 20, 2007 12:46 PM
I been noticing this weird clacking noise coming from the front left side. The noise only is there when I am driving around 5 mph. The noise more like a clack clack clack then as I go faster it would go away. I would also be on the hill parked upwards then I would put the car in D and drive off the clacking is there untill I pick up more speed then it gets quiet. I am thinking it's my drive shafts or cv shafts. anyone. Thanks.
vqmaxman Sep 20, 2007 02:16 PM
anyone with any clue
Punk In Drublic Sep 20, 2007 06:01 PM
I have the exact same rattle in my 96 GLE, it's pissing me off. let me know if you figure out what it is.
I look around and found this... doubtful that this is the cause but it's always possible.
http://maxima.theowensfamily.com/tsb/NTB98-023.pdf
67whitegoat Sep 20, 2007 06:18 PM
Clack clack clack it typically CV joint. Go to a parking lot, turn the wheel to the right and accelerate. If you get a clack clack clack.....
vqmaxman Sep 20, 2007 08:59 PM
Originally Posted by 67whitegoat (Post 5956369)
Clack clack clack it typically CV joint. Go to a parking lot, turn the wheel to he right and accelerate. If you get a clack clack clack.....
I've also heard if you can just turn the steering wheel in either direction you could also hear the clicking noise that means it's the cv joints vs the clacking I am defently sure that it's the cv shaft but it's to hard to know what it clearly is.
maximak1d Sep 20, 2007 09:12 PM
i have a similar problem maybe even the same thing (hard to tell without hearing ur sound)
mines more of a ticking mixed with a shhhhhhhhhh
and it starts wen i start my car and accelerate around 5mph-20ish but after a while it stops
and its not too loud,
i have a 06 max with 9k miles so i unno wut it could be
20" Max Sep 20, 2007 10:24 PM
I have the same ticking problem, I don't have a clue what it may be. I saw that my outer cv boot has a slight tear in it but not sure if that is causing the prob.
helps Sep 20, 2007 10:38 PM
are your lugnuts loose?
vqmaxman Sep 21, 2007 10:19 AM
From what I heard is that if you have a slight tear in the boots you should get it replaced immediatly. If not the axle can go bad cause all of the grease can leak out of there. and your axle will be bone dry.
vqmaxman Sep 21, 2007 10:20 AM
If my lug nut's were loose I believe I would of have had the car fall out while I am driving at high speeds or at turns or the threads stripping.:rolleyes:
vqmaxman Sep 21, 2007 11:16 PM
I have 2 clips that I rec I hope this helps out.
I have the first one here and it's outside of the car near the front wheel.
http://i238.photobucket.com/albums/f...0921071906.jpg
I have the second one that's inside of the car. (Crank you vol up on this one)
http://i238.photobucket.com/albums/f...0921071926.jpg
If you guys can't tell what it is then i will try to do it on the cam corder.
Snypa Sep 22, 2007 07:15 AM
def cv joints,also try turning your steering far right or far left and reverse slowly.
JtzMax Sep 22, 2007 08:03 AM
could also be a tie rod end or ball joint too
did you check the lugs .... ??? They may not fall off ya know. I did my brakes a while back and forgot to tighten them up ... snugged em before I dropped the car back down, drove out to a mates house (45 min's away) and on the way home I remembered that I didn't tighten them all the way. Made a slight clicking noise and that is what made me remember.
Also ... to check CV joints, you need to be moving, not just crank the wheel. If it's CVs, you may also feel it "jerk" at take off or let off of the throtle.
vqmaxman Sep 22, 2007 10:15 PM
I always make sure that the lugnut's are tight and I always work my way around the vehicle so I have tighten them all out. I checked out the ball joints and the whole suspension I believe everything is rusting out but not to much. I also feel a slight viberation on the tie rods I am not sure if your supposed to feel them or not when I have the car on the jack.
