Anybody's driver's side front door locks crapped out?
Mine simply will not work with either the keyless entry FOB or the switch. All the other locks are working. What can be done? Is it time to visit the junkyard or can I just pop something back into place?
same thing is staring to happen to mine although i havent had the keyless entry for like 4 years lost the fob and to lazy to get a new one but now its getting tricky to unlock the doors from the drivers side. hope it wont cost me to much i think i might need to get a new door lock and key if thats the case i think i might shave the doors good luck and let me know if any one has a more helpful answer than me
Originally Posted by massfastmax
(Post 6128911)
kinda happened to me when i first bought my max ... the driver side door never locked!.. even if you used the key or watnot... it would never lock... i ended up swaping out the entire locking mechanism... the actuator still worked (check urs)... just changed the actual lock itself... after that... no problems
actuator = receives the electronic signal to lock/unlock doors. located lower left hand corner of driver side door. (each door has one) |
Cool. I guess to the junkyard I go. Or I suppose I should check eBay too.
| All times are GMT -7. The time now is 03:46 PM. |
