Lean bank 1
Lean bank 1
Also known as the rear. I get this code 0115 and another 0201 for a missfire. The missfire code would usually be followed by another to tell you which cylinder is missfiring. I did the ohm test on all 6 coilpacks and they ranged from 15-17 ohms. I think its a fuel injector? You know what that means, i gotst to pull off the intake manifold to get to the injectors. I have to replace the the valve cover gaskets anyways.
Any other ideas. I have already replaced both O2 sensors
the stealership wants 134 for the fuel injector and 45 for both gaskets.
jmlee44
10-02-2022 02:13 PM
hayne
10-05-2015 11:53 AM
