weird moaning sound...
Ok so I know the title seems a bit....risque haha. But when I turn on my car and drive it without fully warming it up in around 30-40F weather, I hear this kind of...."moaning" ....or rather better word would be a "whining" sound...anyone have this? is it common? I never heard this earlier when it was warmer...maybe something needs to be lubricated more?
auto or manual trany ??? if your a 5spd owner, it could be worn bearings. need more info - where is the noise coming from (which side of the engine bay) how long been happening, does it go away at all ... what if you warm the car up prior to driving?
MORE INFO
MORE INFO
Ok I had the noise again today morning. Even after I warmed it up I could hear it. Last week, when I did pop the hood, it seemed to be coming from the left half. (left half when you are looking at the engine from the front of the car with the hood popped). I think I've heard this kind of moaning/screeching before in cars where the fan belt or something was old or needed to be lubricated? Any ideas?...
Ok, I just had the exact same moaning noise happen at 167K. It lasted a day, got worse, went out to start the car again, got smoke, opened the hood and a couple of flames shot up from the alternator. Just ordered a new alternator and I had NEVER had any noise from my MAX before so it may be worth looking at your alternator as the source of this noise BEFORE you run into a problem. Good luck.
I have a 1997 Maxima that I've owned since new. I noticed a muted moaning noise when cold the first year I had it. Noise is still the same after all these years. My guess is a vacuum diaphragm or valve of some sort that is creating a slight harmonic vibration that has to do with cold start up. It sounds like it's coming from the drivers side of the car and I can also feel a slight tingle from the brake peddle when it is moaning. My car now has 182,000 miles and it has never changed or gotten worse over the years.
In a nutshell, you're checking for belt tension and wear and tear (excessive cracks in the belt(s))
If you can turn your belts more than 90 degrees using your thumb and index finger with moderate force, your belt is too loose. Do this test at the middle point between two pullies. If oose, tighten the belt.
Alright, can anyone point me to where the belts are located? When I open my hood and look at the left side (aka where I heard the noise and if you were in the car, it would be the passenger side) and I look down, I do see one black belt moving...is that the serpentine one?
yes, they are kind of on top of each other/right next to each other. i think the serpentine belt is the one closest to the outside of the car (the left most one when you are looking at the engine). also, the serpentine belt is the big one wrapped around several tensioners. the power steering is smaller.
I agree, but not totally. I have all three (Haynes/Chilton/FSM) and there have been times when the Haynes and FSM is vague/unclear and the Chilton shines. Overall though, I find the Haynes to be much better than Chiltons.
There have been times where I needed all three books to make sense of the task at hand.
IMO, a smart novice DIY'er will have all three, and read each one before tackling a specific job. Haynes/Chilton are cheap, and the FSM is a free download.
/babbling....
/babbling....
Hi,
I had a similar problem. After warm up the engine the sound came out. So I checked the belt, replaced idler pully, and alternator but those weren't help me at all. By the way I found a thread which was written as the problem. The guy told me " That should be vaccum problem so just clean the throttle body, IACV, and ERG(?) up first." I did exactly what he said. The sound was gone after that. Even if the method do not fix the problem, it is worth I think. You will need a throttly body cleaner($3~4 at walmart) and some shop towels.
Thanks.
Thanks.
No offense, but if you can't find the power steering pump, I doubt you can change it yourself. And w/o a manual, you'll really be lost.
IMO, just take it to a good mechanic and let him diagnose/fix the problem. Hope everything works out for ya.
AaronL
11-15-2020 11:52 AM
HerpDerp1919
09-29-2015 02:02 PM
