higher wattage headlights
Old 02-27-2008, 11:25 PM
maxim82's Avatar
i want to get some of these bulbs:
8500K
Plasma-White
Quartz Glass Bulbs
Ion Coating
8500K Plasma White High Wattage 9004 100W/80W
what kind of harness do i need would this do http://cgi.ebay.com/ebaymotors/NEW-N...ayphotohosting or would this work better http://www.autodynamic.com/detail.as...UCT_ID=HH-9004 what do you guys think?
maxim82 is offline
Old 02-27-2008, 11:47 PM
MorpheusZero's Avatar
Don't get them. They will be about as bright as stock if they are really 8500K and they will produce way more heat.
MorpheusZero is offline
Old 02-28-2008, 12:00 AM
maximus_96's Avatar
the ebay one is worthless. the one from autodynamic looks good. i usually build my own, but the price there is not terrible and can save you some trouble.
but at 8500k you won't get much usable light...i would stay away from that myself but i understand a proper HID system is not for everyone.
maximus_96 is offline
Old 02-28-2008, 12:12 AM
Hammy
go for 6500K More than that it's worthless.
Old 02-28-2008, 01:11 AM
ThurzNite's Avatar
I had Mtec 100/80 on stock harness, I think the color temp was 6000. My personal opinion is 8500k is lame. It's so blue, it'd get you in trouble with law enforcement in certain areas here in Los Angeles. Plus, it's useless in rain and fog.
Regarding overwatting, I didn't have a problem with it. I used di-electric grease on the contacts to keep heat to a minimum. Resistance can cause heat, so minimize heat, and you won't be melting anything.
Dr J
ThurzNite is offline
Old 02-28-2008, 06:58 AM
99grnmaxgxe's Avatar
$30 for harnesses? I rather have stock bulbs.
99grnmaxgxe is offline
Old 02-28-2008, 07:16 AM
Shoto925's Avatar
I got sylvania silverstars in mine and they look just fine. I wanted HIDs but I'll be damnded if I'm spending $400 on lights while I have so many other things to fix
Shoto925 is offline
Old 02-28-2008, 07:40 AM
dot dot dot ...
NmexMAX's Avatar
I've fried too many harnasses doing this crap, just use what is recommenced. The most you'll get out of higher wattage bulbs is better snow melt on your headlights during s storm.
NmexMAX is offline
Old 02-28-2008, 07:53 AM
Sold
JSMax's Avatar
or you could switch over to a 9007 bulb and re-wire the harness. 55watts low as opposed to 45 on the 9004.
JSMax is offline
Old 02-28-2008, 03:32 PM
castlemax's Avatar
The risks of running higher wattage bulbs completely outweighs the benefits.
castlemax is offline
04-16-2020 05:15 AM
doctorpullit
10-28-2019 10:58 PM
uttadms31
09-30-2015 05:24 AM
Noela
09-26-2015 08:22 AM
Quick Reply: higher wattage headlights
