How to fix clutch chatter
Searching for threads on clutch chatter beings up a lot of threads but little in the way of how to fix it.
I currently have a 3.5 swap, Stillen flywheel with 5 speed timing ring, Exedy stage 2 clutch, matching PP and throw out bearing.
I have terrible chatter. it chatters up to 3500 rpm in furst, 3000 in 2nd and almost as much in 3rd. I've broken in the clutch for almost 700 miles with no improvement.
Does anyone have any suggestions to get rid of chatter? I might even pull the flywheel and Clutch and get them balanced. If you have suggestions post them here. Thanks.
Coremanx--I installed the clutch when I did my engine swap
Greeny--It happens more when I slip it, obviously. But I have to do that in at least 1st gear or it's almost impossible to do a smooth take off from a stop.
What do mean by "more"? Is the car chattering even when it's in a gear/w the clutch pedal out? need more details here.
