knock sensor code
Old Mar 25, 2008 | 08:12 AM
hotimportnight9's Avatar
knock sensor code
i just replace the ks today and clean the ground points but when i hook up the computer to it and erase the code it still comes on i try reseting ecu still there i drove around and it still there code i get is p0325 also the check engine light is not on
Old Mar 25, 2008 | 09:48 AM
watut's Avatar
Cheap gas? maybe you got a defective o2
Old Mar 25, 2008 | 10:02 AM
i use 93 at mobil i treat my baby good but the o2 would that trigger i different code?
Old Mar 25, 2008 | 10:17 AM
ROCKART's Avatar
wants an I35
maybe the new ks was broken when you got it ?
Old Mar 25, 2008 | 10:43 AM
Crusher47's Avatar
You gotta drive it 150 miles or so to clear it out (assuming the new sensor isn't defective)
Old Mar 25, 2008 | 11:01 AM
ill try 150 miles and then check will post the update. thanx
Old Mar 25, 2008 | 11:23 AM
Snypa's Avatar
^^^ OMG
Old Apr 1, 2008 | 02:13 PM
webjohn's Avatar
wait a minute cant you reset the codes manually.
or am i completely missing this here
Old Apr 1, 2008 | 02:38 PM
NmexMAX's Avatar
dot dot dot ...
Yes you can rese/retrieve the codes manually. i also have not seen anyone here suggest that perhaps the KS harness was/is to blame?
I'd look into it:
http://www.courtesyparts.com/Merchan...Category_Code=
ballerchris510
Sep 23, 2015 08:46 PM
homeofbacon
Sep 23, 2015 07:17 PM
ac max 92
Sep 17, 2015 07:35 AM
