Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Rpm's rise and fall (https://maxima.org/forums/4th-generation-maxima-1995-1999/563167-rpms-rise-fall.html)
Scottyboi May 27, 2008 07:27 PM
Rpm's rise and fall
Well my rpms when i first start the car will idle between 1500-2000rpms....then if i turn the car off and turn it back on within a couple of hours..the rpms will stay at 3-3500rpms. Is my tps going out? or is it my maf?
is there a way to reset any of them?
maximase86 May 27, 2008 07:45 PM
ECU throwing any codes? I would imagine if the TPS was going, the car would throw a code for it.
S
Scottyboi May 27, 2008 07:53 PM
I havent taken it to autozone.
When my car set up, the guy that did my car didnt connect the SES light..
Scottyboi May 28, 2008 10:07 PM
anyone have an idea?
fat_kid May 28, 2008 10:24 PM
Idle control?
Bandfan1024 May 28, 2008 10:30 PM
Any chance your check engine light is on?
4DSCDriver May 29, 2008 09:09 PM
The computer can still store a code even if the SES light doesn't show it right?
j2b4osan May 30, 2008 05:31 AM
from what I gather from searching on the org is that manny people have experienced simmilar problems on 4th gen. And even stranger is that after reading all the threads it seems as if no one has been able to pinpoint the culprit. Some people change ignition coils with no improvement, Some people remove the fast idle plunger to keep the revs down but this is merely masking the real problem which to my knowledge is still unknown. I myself have the same problem from time to time but not always bit if I manage to figure it out I will be sure to post. My only advise is that its something to do with the throttle body and the surrounding sensors (I think) so replacing the throttlebody may help.
modenaf1 May 30, 2008 12:15 PM
Perhaps idle air control and or vacuum leaks? Maybe a stuck throttle too? Something has to be letting more air in, if all it was was the TPS reporting a false reading but everything else working perfectly, in theory there shouldn't be enough air for it to possibly idle at 3500RPM.
mevjen May 30, 2008 06:54 PM
Maybe your coolant temperature sensor is bad?
j2b4osan May 30, 2008 07:44 PM
this may sound like a stupid question but should the idle air control valve make a tick noise when the car is at idle?
mevjen May 30, 2008 08:39 PM
Are you sure that isn't coming from your fuel injectors?
j2b4osan May 31, 2008 05:28 PM
positive
vilmaxima May 31, 2008 06:14 PM
Is it a tick that comes on after the car is warmed up? the fuel injectors make a tick too, but if its what I think u are talking about, its slower than the injector and louder and starts when the car is warmed up. I got this issue too and thought that it may be the evap purge volume control valve, or the evap purge control valve, bot on top of the IM, replaced those with ones i got from a junk yard, its still there(the noise) I think it might be the evap purge valve, I had this code before, but then it just went away.
vilmaxima May 31, 2008 06:16 PM
Thats right, ghost codes. Like the one I got P0500(vehicle speed sensor) no SES, but checked OBDII, and there it was. Now that I think about it thats tranny related, and checking the tranny code manually, did throw it in my case.
