got SES light today .. how much $$ am I looking at?
P0325
Knock Sensor -- not worried, this itself won’t cause SES light
My main concern is:
P0105 and P1105
These 2 seem to be related.
P0105 is described as: "a malfunction in the electrical circuit for the manifold absolute pressure sensor or the barometric pressure sensor"
P1105 says "MAP/BARO pressure switch solenoid valve"
My car knowledge sucks. I would appreciate any help here. Has anyone had any problems with the P0105/P1105 codes? How much did it cost to fix? Thanks.
My main concern is:
P0105 and P1105
While the knock sensor wont cause a SES light, it can mess up your car's performance. So that's something you should look into.
As far as the absolute pressure sensor, your first step should be to visually inspect it to make sure it's not unplugged or something simple light that and trace the harness to make sure all those cables look ok. I believe the sensor itself says "Boost Sensor" and is located on the front side of the engine bay right by the intake snorkel on top of the radiator.
Given that the common problem with both codes is the absolute pressure sensor, I'd start there and make sure the harness and everything is properly connected. It could be a free fix.
Those codes are interrelated. Meaning that if you fix one, the other one normally goes away. The MAP/Barro switch is just to the right of the front valve cover. I replaced mine and both of my codes went away.
the autozone guy was showing me the part that i needed but i wasn't really paying attention. i had a terrible head cold.
Any luck fixing it? I had a check engine light a while back, but it went away before I could bring it in.
I just brought the car in for state inspection and it failed the OBD test and I got those exact codes....
P0325
P0105
P1105
I definitely could use some help!
P0325
P0105
P1105
Actually I didn't even read the thread, it's already been suggested.
Why don't you follow the suggestions above, and actually test something?
Where is the switch in relation to the sensor? Autozone is quoting me about $150 for the sensor, so I want to narrow it down a bit before spending that much.
I dont have the tools to test the sensor, unfortunately, but I did just run to autozone (actually had to go to 3 different autozones) and buy a new one. It was very easy to swap out. Unfortunately, the CEL is still on. Should I reset and see if it comes back or will it, as the folks at autozone said, go away after driving for 60 miles--they wouldn't clear it with their OBD tester.
I asked everyone if they had the MAP/Baro solenoid valve and no one knew what I was talking about.
All of the hoses and connections look good.
I'm a first time fixer and searching this board has been tremendously helpful so far. Thanks!
Thanks for the heads up. I called the dealer and I'm on my way to be out another $107! for a small piece of plastic. I hope that this is it!
I'm guessing that both the sensor and the solenoid didn't go bad at the same time, so maybe my old sensor is still good.
look here as well. Pull the codes yourself, research the problem and reset the code yourself.
http://forums.maxima.org/4th-generat...ere-first.html
definitely let me know how this goes, after i did my dek swap i have the p1105 code. i havent tested anything tho.
could this possibly have anything at all to do with me removing the EGR valve and some of its components? i traced hoses all the way from the boost sensor. somewhere down the path, iirc, the hoses head to EGR through a series of valves, hard lines, etc. correct me if im wrong, maybe ill check myself later on today.
Same codes still come up. I changed all of the vacuum hoses off of the solenoid and the sensor. My only thought is that I've either got a bad new sensor, the knock sensor is causing all of this, or I've got an electrical problem.
If you haven't, clear them and see if they come back.
Mine keeps coming back as well.
I've tried three different boost sensors and a total of two MAP/Baro SSV's. I checked the hoses on SSV and they looked fine. Maybe I should disconnect them and blow through them to make sure they aren't clogged or something (didn't think of that when swapping stuff).
MaxLife17
06-27-2019 01:37 PM
yat70458
08-03-2015 01:16 PM
