98 Maxima high RPMs
98 Maxima high RPMs
I have a 98 Maxima GXE, automatic with 240,000 kms and am experiencing
highs revs.
At 100km or 60 MPH it reves between 3000 to 3500.
Interesting thing is I turn off O/D and there is no increase in revs. I even dropped to 2 gear and it stills revs the same?
Any diagnostic?
highs revs.
Any diagnostic?
Yes, It seems so. I havn't tried shifting first to second, so does this sound like an expensive tranny job?
Limp mode: will try disconnecting battery for 5 min to reset computer.
If anything, it isn't shifting into O/D. Possibly the torque converter? And to the posts above, the Maxima isn't shifting out of 3rd. If it wasn't shifting out of 2nd at 60 mph, the RPM's would be closer to 6k.
In any case, the first thing to do is see if the ECM or TCM are setting any codes. That should've been the first diagnostic the OP did on his own anyway...
After parking it at work and going home, all seems to operate as normal.
This morning, the cold start did not go very well, I thought the engine would stall, but maybe should have warmed up a bit. It was also very rainy and humid.
That said, maybe this is the start of tranny going down? I have noticed not too smooth shifting in higher gear when I accelerate recently.
Will try the manual code as well.
Wow, 5-6K for tranny. I thought they say these cars can last forever?
You can get a brand new RE4F04V from Nissan for ~3k or so, they're not too expensive. Rebuilds can be about half that.
Did you check the TCM diagnostics as well, or just for the ECU?
It's in the same FAQ as checking the ECU codes - http://forums.maxima.org/1001794-post2.html
Tried the TCM as your note and Haines manual, but no flashing light.
So it doesn't indicate a problem, but that diagnostic is really top level.
O/D works fine now, does rev when activated.
But this incident could be the start of tranny problems.
LOL wow, that's just your bad *** luck. Who goes through that many Trannys on one car, LOL. I have a manual trans and it's still running strong, almost 200,000 miles. My previous auto trans on my other maximas never went bad, and they had high mileage too.
KRRZ350 was just telling me the other day one of his customers (or customer's friends, I forget) has done the same thing, 4 autos. Merlyn's on his 3rd 6MT...everyone around me just has trans problems.
To the OP is there any signs of slipping with the trans when shifting? How does your fluid look, still pink/red? Maybe you should find a TCM from a junkyard and when you have signs of trouble swap it out. Could possibly be the TCM failing sporatically...or it can point to the tranny itself.
S
Hesitation could be an engine issue rather than transmission.
Just an unlikely thought if the 98 auto shifter is like the 97: Does your OD OFF light toggle on and off when you toggle the OD switch on your shifter? I imagine this switch could go bad.
kjlouis
11-24-2018 06:09 AM
Finkle
09-27-2015 09:53 PM
