can't get in reverse!!
i have a problem...the car won't go in reverse or get into 1st gear...i have a 98 auto..
i was parked and wouldn't go in reverse so i put it in neutral and pushed it back and put it into drive and started driving... when i put it into 1st...the car just revs as well as when i put it into reverse ne solutions??? thanks |
Have you checked your transmission fluid level?
yes...i checked and it's at the right level...although it looks kind of dirty...should i flush the tranny fluid out??? if so, is it difficult?
That is the first thing to check. You might have lost your trans ... check the fluid and report back
i checked it and it's at the right level but doesn't look bright red...duller and looks thinned out???
is it difficult to replace the tranny fuild? and how?...i looked under the stickies already and didn't find out how to flush the tranny fluid |
I have a good feeling your transmission has crapped out on you. =(
yea, if the fluid level is ok, you probably lost a pump inside the trans. any funny noises?
I would say out. that happend to me in a school car it was a neon but the exact same thing I should ask them what the shop had to do to fix it.
any who there is a drain plug on the bottom of your tranny. |
update...
took it to my friend's dad's place and he scanned my car for error codes and came up with: P0325 P0744 P0731 what do i do now? |
i was thinking it could be a hydraulic control circuit problem??? b/c P0744 and P0731 both refer to hydraulic control circuit as a probably cause...and i'm thinking that the P0325 knock sensor code doesn't really affect the reverse and 1st gear problem???
Originally Posted by Llfe
(Post 6637465)
Most likely your solenoid pack, if you're on your original one. Nissan released a TSB about them, along with updated kit. |
I agree with Pmohr .... you probably lost a pump or solinoide pack and that is why it's throwing you those codes. And, you're right ... the P0325 (KS) has nadda to do with your trany. Time to start looking for a good used one. I saw one local (SW Missouri) for $325 a week or so ago. It was out of a 00' with 65k miles. To give you an idea anyway. You can find good deals, just gotta look around mate. G'luck!
should I replace the solenoid or just look for a new tranny??
def new tranny :(
yea, the solinoide pack is inside the trany ... look for a new trans. to get yours rebuilt, you're probably looking at ~$1500 or so, likely more.
dumb question but...how do i know if my maxima is the locking or non locking differential transmission?
(Post 6640110)
Assuming the trans has never been swapped out, check the VIN plate on the firewall. RE4F04A is open, RE4F04V is VLSD. |
| All times are GMT -7. The time now is 03:17 AM. |
