Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Something's rubbing (https://maxima.org/forums/4th-generation-maxima-1995-1999/573963-somethings-rubbing.html)
crazyrodent Oct 15, 2008 01:33 PM
Something's rubbing
about 2 weeks ago i started to hear a rubbing/grinding noise when braking. i thought it was the wear indicators on the front brakes (the rears had just been replaced, pads and rotors)
now there's a vibration and noise when i drive. kinda feels like a tire is out of balance or flat but there's a grinding sound and thumping/tapping that increases with speed. if i get on the brakes slightly hard it isn't as bad.
i'm planning on doing the front brakes this weekend but it seems like it's more than just brakes.
what else could it be?
95 max gxe auto non abs.
jcunion413 Oct 15, 2008 02:31 PM
My guess:
Brakes. But just in case, might want to check you CV boots for cracks and check if you see any grease around it. Highly dobut that be the case but never know.
Edit: internet went crazy and posted my half completed post
fourstaroots Oct 15, 2008 03:07 PM
ive heard of brakes doing this when a rock or something gets in there
webjohn Oct 15, 2008 07:03 PM
something's rubbing alrite.... naughty naughty
crazyrodent Oct 15, 2008 08:01 PM
i'm wondering if i will be able to make it 100 miles to my parent's house so i can fix this. i'm afraid it's going to explode on the freeway
crazyrodent Oct 20, 2008 10:51 PM
so it ended up being the lug nuts. on one wheel, one was hella loose and a few others were not that tight. it was odd because i made sure they were torqued correctly when i replaced the wheel bearing.
i ended up replacing the pads and rotors while i was at it. i bought new lug nuts as well.
