80MPH at 3400 RPMs?
Hey does this sound right? I have a 5 speed. I just cleaned the throttle body, new air filter, and a new PCV valve. I didnt clean the IACV or change the fuel filter could that be why the RPM's are so high?
Physically impossible for that to cause a change in your tachometer reading. The speed / RPM is mechanically governed by things like wheel size, transmission ratio, etc. The ECU is programmed with the speed vs. RPM and will not change.
80mph/3400 sounds about right. What size tires are you running, and on what rims? |
I have on the 2001 stock 17inch rims.
Maybe I am just used to my mustang which cruised at 2000 RPM's on the highway:goofy:
Yep, that sounds about right. I really wish we had a taller 5th gear. The car definitely has enough torque to cruise at 80 or 90 at 2500 rpm just fine.
Yep its normal, wheels will not affect the engine speed reading from the tachometer. It might not be 100% accurate, I know that mine reads about 100rpms higher than it actually is revving, due to having a VAFC-II.
It does suck that our 5th gear isn't taller but oh well, I still get 27 mpg if I drive easy on the pedal and all highway. |
Sounds good. I know that 5th tops out at about 143 lol.
sounds bout right, swap in a 6 spd if you don't like it :p
I agree, sounds about right. :)
Originally Posted by fat_kid
(Post 6662041)
I might just have to do that one of these days. And a VQ35 to go along with it. And forced induction to go along with the VQ35. And...god damnit this hobby is an addiction I tell you!!! |
Is there a reason Nissan didn't make 5th taller? It spins pretty dang fast, it gets annoying when you're out in the middle of nowhere and are cruising at 85-90 like everybody else.... My mom's 00 I30 is a good bit slower, which seems a bit counter intuitive, does it not?
While we're on the topic, how do you guys feel about the ratios of the 5 speed? That is, is first too short compared to how long second is, etc.. |
Thanks guys for all your information it is greatly appreciated.
It's a maxima, not a ferrari. I think the ratios are just fine.
I suppose a taller 5th might help fuel economy, but if you need to push hard on the gas in 5th to accelerate you can pretty quickly eat up the fuel savings that you saved while cruising. Dave |
yeah 5th is short, my car feels strung out crusing at 80-85 like. but 5th gear definatly pulls real nice. and yes it will do what it says on the speedo.
with a lightweight flywheel my car now cruses just about 3050 rpm @ 80. I believe nissan designed the fifth gear so that you wouldnt have to downshift at highway speeds to pass, as the torque curve on the vq really kicks up around 3000 rpm
Originally Posted by ozzombie13
(Post 6663113)
i know i'm in the wrong forum, but the 3g 5spd is basically the same way. pulls good in 5th but screams along at an even higher RPM than the 4th gen 5spd... i'm turning 3000 at like 75mph. so what i'm planning to do is replace my 5th gear (in/out) with the correlating parts out of a 2nd gen transmission, to give me a longer 5th gear (.745 instead of .790). if any of you are handy rebuilding manual trannies, this may be a direction some of you will want to look into, providing that the VG tranny parts will match up to the shaft splines on a VQ tranny. |
(Post 6663133)
Can you grab a pic of that 2g gear and pm it to me, I will let everyone know what's up. His post doesn't make sense, 80/3400 is about right.
Originally Posted by kzoosho
(Post 6662027)
Thats weird. Ive gone 145 and i still have like 600rpms more to go before i redline. |
Originally Posted by maxima.713
(Post 6663195)
Originally Posted by KRRZ350
(Post 6663187)
but currently i lose 33% rpm from 3 to 4, and a scant 20% from 4 to 5....... using a 2nd gen 5th would drop me by 29% into 5th which is much more comfortable. |
4th generation 5th gear ratio
Please post what most economical solution to 5th gear ratio reduction!
I wonder if replacing entire tranny with "lower RPM" box out of another Gen/Altima is the least expensive or getting gear to match current tranny... either way, labor costs will make this a *#&**$$$. I agree, that our VQ does NOT need such a high RPM "cruise gear" as it easily passes traffic in 5th gear below 3K!! If you need to "blast around someone" pull it back one gear! My auto has perfect OD gearing and cruises at below 3K (30MPG) at 75/80... I NEVER have to downshift out of OD to easily pass.:kiss: |
Originally Posted by packerZ
(Post 6663259)
It is probably more economical to have a taller fifth, since the fuel economy testing of 1993-94 were based on a "highway" speed topping out at 60mph. (http://www.fueleconomy.gov/feg/fe_test_schedules.shtml) Most of us drive on highways much faster than that. The optimum overdrive ratio will change if designed primarily for 75mph. All that said, changing 5th will require that the synchros be compatible and the splines line up. I have several spare 5ths and shafts laying around from a 4th gen, but I don't have any altima or 2nd gen maxima parts. It's entirely possible that the parts are a drop in just like the 3rd gear from an altima is. If someone had the proposed gear parts handy we could figure out if they will fit. The trouble with this exercise is that if you're paying a shop to change it you'll never recover that cost in fuel savings. Even if I'm doing a rebuild for someone and the labor is a non-issue, I still need to have the spare gear parts hanging around or bastardize a core. So that further adds to the cost and difficulty. Dave |
I guess the reality of my question is: gears/tranny swapping "not even practical" until tranny is ready to be re-built! At that time the specs of each transmissions' gear offerings to gain "optimum" gear selections could be factored. However, really all I want to get is a 5th gear replacement on my 4th gen 5speed that was much lower RPM (a real O.D. drop).
Yet, I realize that even if someone had such a 5th gear-conversion tranny made-up or replacement/crossover tranny w/desired 5th gear ratio just laying around, I'd have to wait for tranny R&R-time labor $$ to make sense... and not really wishing it to be soon! Even though I want that gearing!!! :) |
6-speed
If you are going through all this trouble to make a better 5-speed, why not swap a 6-speed. Not practical for Capedcadaver, vg, not vq, but for everyone else... I know it is work to go from rod to cable, but designing a transmission is also pretty tough
Originally Posted by augiedog964
(Post 6663521)
But even so it may be possible for me to do that on my current engine, with a bellhousing adapter, if I ever learn how to weld and fab metal things. i thought there was a sticky for the 6spd conversion somewhere, right? |
at 80 mph my rpm is at 3000 steady, i have an outo tho.
Originally Posted by s0mbra
(Post 6663594)
(Post 6663195)
Originally Posted by khantalha
(Post 6663708)
same here, i think it tops out at 153-155 mph with a factory rev limiter
Originally Posted by 99BlackMaxMS
(Post 6663741)
The only 4th gens that have speed limiters are GXE's and they quit at 118mph.
And that's disappointing, I've never bothered to get top speed cause it takes too long. Guess I just gotta pack some more power.
Originally Posted by modenaf1
(Post 6661972)
(Post 6663133)
uh... wha? you mean on your stock flywheel your 80mph RPM in 5th was different? or am I misreading what you said?
This thread is completely worthless.
(Post 6664292)
yes it was just around 74 @ 3000rpm with the stock flywheel, so 80 was around 3400-3500.
If it changed, it's because of something else. Drive ratio can only be changed within the transmission gearing. Dave |
yea thats true.. ur directly coupling to the engine.. what would a flywheel have ANYTHING to do with engine speed... (other than acceleration)
Originally Posted by f550maranello2
(Post 6664475)
(Post 6663741)
True that my last 2 4gens would top out at 118. witch was realy gay. now i dont have to worry bout that anymore. |
ooohhhh another mustang guy. The speeds sound about right. They are totally different than our stangs. Check out my babies below...
http://a4point6gt.mypicgallery.com/S...-553_large.jpg http://a4point6gt.mypicgallery.com/S...-555_large.jpg |
^^what the hell
© 2024 MH Sub I, LLC dba Internet Brands
