Can't Find Keyless Remote Instructions
I know, check the stickies. I've been through them for almost an hour and I can't seem to find them. Maybe I overlooked it somehow, but I'm looking for the instructions. Please HELP
From the stickies:
ID Code Entry Procedure To enter the ID code, follow this procedure. Entering "Setting mode": (1) Close and lock all doors. (2) Insert and remove the key from the ignition more than six times within 10 seconds. (The hazard warning lamp will then flash twice.) At this time, the original ID codes are eliminated. ID code entry: (3) Turn ignition key to "ACC" position. (4) Push lock button on the new remote controller once (for example, if door is locked using the remote controller during this ID code entry enable state, a new ID code can be entered). At this time, the new ID code is entered. (The hazard warning lamp will then flash twice.) Additional ID code entry (5) If you need to activate additional remote controllers, unlock the driver's door, then lock again with door lock knob. (6) Push lock button on the additional new remote controller once. (7) This ID code entry enable state and setting mode remain until the driver's door is opened. |
takes just a lil search.
I dont know if I read it wrong, but the other keyless remote tut. did not work, I tried it for hours. I'll try this one now. I think I know why its not working for me, I have a different key, not the same as the original Nssan maxima key, its from a hardware store. Its doesnt fit the the ignition all the way, so I have to jiggle it sometimes to make the car start.
make sure you have the keyless module in your car, loccated by the jack in the trunk
Thanks! I'll try it out.
| All times are GMT -7. The time now is 07:33 PM. |
