Timing Chain 96 Maxima SE
I replaced the timing chain after 177,000 miles and boy was it a lot of work. My symptons were the car was very noisy one morning, to me it sounded like a timing chain. I drove the car up to 80 mpg up to the dearleship. The dealership said it was a timing chain $1800, they gave me a copy of the TSB's. It was not the timing chain but tensioner leaking, see TSB. I have a question, if in fact the timing chain had slipped a notch, wouldn't my engine have been damaged? How many notches can it slip before damage?
If it slipped only one notch, hasnt it just advanced or retarded the timing by a couple degrees? If so, it probably wont hurt the engine, just your performance. If it did advance it, wouldnt the knock sensor retard the timing anyways?
If it keeps slipping, that could be a problem... |
had my chain replaced
Bought my 96 gle (100k on miles) a few months back, thankfully the guy was honest and let me know about the problem (and had it priced appropriately). So I had it replaced for a little cheaper than you were quoted and it's ran smooth ever since. Don't know what that says about any long term damage but it seems like I would have felt the reprecusions(spelling?) by now. I'm not sure if I'm addressing your particular problem but I hope this helps a little. :p
Re: Timing Chain 96 Maxima SE
Originally posted by BattleBotsJudge I replaced the timing chain after 177,000 miles and boy was it a lot of work. My symptons were the car was very noisy one morning, to me it sounded like a timing chain. I drove the car up to 80 mpg up to the dearleship. The dealership said it was a timing chain $1800, they gave me a copy of the TSB's. It was not the timing chain but tensioner leaking, see TSB. I have a question, if in fact the timing chain had slipped a notch, wouldn't my engine have been damaged? How many notches can it slip before damage? |
Re: Re: Timing Chain 96 Maxima SE
Originally posted by cbr2 To my understanding one notch and your car will run like crap.. More then that and your heads are toast.. (might be 2 or 3 you can go before toasted heads) None the less you need to fix it ASAP!!!! Im not sure of the tensoner price but I would be doing this job myself.. This is only 1.5hrs more then a water pump job so you should be replacing that too and oil seals.. It is a time consuming job and scarry as hell to do but if you rotate the crank to TDC and be rotate your cams back to their mark you should be fine.. Just DON"T rotate ANYTHING when there is not chain except moving the cams back to their mark.. And be careful because the left cam(closer to the car) is in tension and likes to fall left and right.. (it is OK if it falls because those are the valves closing but be sure to rotate it back the way it falls. |
Re: had my chain replaced
Originally posted by BlancMax Bought my 96 gle (100k on miles) a few months back, thankfully the guy was honest and let me know about the problem (and had it priced appropriately). So I had it replaced for a little cheaper than you were quoted and it's ran smooth ever since. Don't know what that says about any long term damage but it seems like I would have felt the reprecusions(spelling?) by now. I'm not sure if I'm addressing your particular problem but I hope this helps a little. :p |
Originally posted by AdMax98 If it slipped only one notch, hasnt it just advanced or retarded the timing by a couple degrees? If so, it probably wont hurt the engine, just your performance. If it did advance it, wouldnt the knock sensor retard the timing anyways? If it keeps slipping, that could be a problem... |
© 2024 MH Sub I, LLC dba Internet Brands
