Any suggestions for more 'howto' tutorials? Post them here.
No more Maximas...
Replacing the Knock Sensor - Part 1 | Part 2
Checking/clearing CEL codes
Replacing the Ignition Switch
Removing/replacing the gauge cluster
Changing the PCV valve
Changing spark plugs (outdated)
Removing hood struts (outdated)
Removing/replacing the rear door panels
Removing/replacing the front door panels
Replacing the starter
Replacing foglight bulbs
Replacing the front brakes
Replacing the rear brakes
Changing the AC/Alternator belt
Checking/replacing ECTS
Removing/replacing power antenna assembly
Replacing the outer tie rod ends
Replacing the radiator
Replacing the PS belt
Replacing the evaporator
Disassembling the evaporator box
Replacing the AC compressor
Replacing the LCA
Replacing the front window regulators
Replacing the water pump, part 1, part 2, part 3
Replacing the fuel pump
Replacing 3rd brake light
Replacing rear view mirror
Replacing steering wheel
Replacing hood struts (updated video)
Replacing coil packs/spark plugs (updated video)
Replacing rear strut mounts
Replacing the LCA
The EGR tube clean out seems to be a popular issue. You might want to combine it with the ever necessary upper intake removal & rear VC replacement. Kinda involved I know, but put it on the back burner, and serve it up when you get a chance.
The UIM removal would be great for a NEWB!!!!!!! Especially since shops want around 300 to remove. I can do it in under 20 minutes!!!!!!!!!!!! Well the 300 included removing UIM and removing rear vc. Still seems insane for someone to pay that.
You could do some on cleaning the TB and IACV. I've seen lots of questions in the past on how to do those. And it wouln't take you long at all to do that.
perfectly honest.. the org posses so much knowledge that i cant even think of anything that needs to be how-to'ed. mabey you could make an effort online here to gather some of the 3.5 swap info that seems to be scattered and get all of the general questions answered rather than havonig to read through multiple threads and such for general info.. im not saying DO a 3.5 Swap even though your fully capable im sure. im jsut saying that ive seen monkey **** fights more organized than some of that info.
that and. well the FSM pretty much tells you step by step how to build a maxima.. so my idea would be to help the helpless and see whos left over doing what.
we need new mods.
we need new mods.
i think it will b nice to just have one thread that posses a ton of different info.
heres what i used to have to do.
1. figure out what im tryin to do
2. search and search and gather some info ( this was before i found the relevancy button)
3. if i dont find what im looking for i make a post about it.
4. 25 seconds later i get slammed by someone (pmohr) and he gives the link.
seems like this is just gonna save a lot of time.
+2 great idea and im sure he will do.
00vi needs one badly. There is no real right up on it and how long has that mod been available.
Iacv cleaning, Tb cleaning, VC gaskets, Radiator, themostat, injectors, Lower oil pan, Oil change, Bypassing the TB coolant lines, brakes and rotors, wheel bearing, Water pump and tensoner I know alot of these are common sense to us but someone who is not to mechanically inclined its not and this would be huge to them. But it seems like thats the kind of audience you are aimming for
I know you dont want to rip apart your car to do a writeup. But when you do them just cause you need to do them dont forget to video tape
Yeah that would be nice. I'm sure I could figure it out myself, but I would rather be shown so I don't screw something up.... and seeing it done is a lot better for me than reading about it.
TB and IACV are pretty hard to screw up.
What we need are tuts that there are for either "old" how to threads with the pics missing or complex things like replacing an auto tranny, replacing the steering rack, etc.
antenna mast
Antenna mast. I read six posts before I finally got the small bit of info i needed (remove the chrome nut/bezel first. I just think a detailed how-to with short video would be good there. Aaron
No more Maximas...
Took some quick vids on plugs/PCV. They're not as in-depth as the other videos, but it's a rather simple job.
Have to upload them to YouTube, should be up there in a couple of hours. For simple jobs like this, I probably won't do a picture tutorial (as many already exist), nor a post on the org. Subscribe to my channel or check the 'Howto' playlist for new videos.
Workin on the 00VI writeup... page 17 right now. I need to finish it. :/
That being said
-How to take the door panels off [pics are broken]
-How to adjust the trunk latch
-How to remove the front bumper
-How to remove the fenders
True but i know he is trying to aim for the newbies. Yes alot of them are very simple but they are not so simple if you never have done them. Its always nice to have something to "show" you how to do things the correct way.
Hell when i first started here i didnt even know what a TB and A IACV was. Now i dont even have a IACV
LOL cluster. strut bar maybe....... jk
+1 on EGR tube removal and cleaning. It would be kinda hard to get a camera in those places with the engine in the car though... And yours may have mysteriously disappeared in 00vi swap
Also, maybe changing calipers -> bleeding brakes.
EDIT: isn't there a EGR work around, maybe you could throw that in somewhere 00vi
I personally would like to see how to replace an auto tranny
probably everything, not necessarily looking to do anything, just talking out of my head.... but then again everything mentioned thus far has been covered before. not to mention its all in the haines manual or the fsm.
lol dont get him started..........
He does do nice things for people as long as one makes a effort. Hell even when you ask a completly newb question,he will give you the links, then he will just speak his mind as you very well know..........
yea , he just bashes on me telling me to search . i give him props for what he been doing ..
