HID's on '95-'96
Has anyone done an HID conversion on a '95 or '96 without changing their headlights to the '97-'99's?? If so how is the beam pattern??
I'm sure the beam pattern would be just as bad as it is on the '97-'99 models. nm
Originally posted by BillN Has anyone done an HID conversion on a '95 or '96 without changing their headlights to the '97-'99's?? If so how is the beam pattern?? |
Blurry, but bright. It took A LOT of reaiming.
Doyou like what you see?
Reaiming is fine but do you like the HID's?? Do you still use your fog lights??
Re: HID's on '95-'96
Re: Re: HID's on '95-'96
Re: Re: Re: HID's on '95-'96
Originally posted by BillN Sorry, but I did SEARCH (by the way stop screaming)and this thread did not answer my questions about the '95-'96 headlights.:) I love when people think they know everything and tell you to search. NOT EVERY QUESTION HAS ALREADY BEEN ANSWERED PEOPLE!!! Don't let the first words come out of your mouth to be SEARCH! Bill, I would wait until the HID's can do both high and low beam. Erik |
Originally posted by medicsonic Blurry, but bright. It took A LOT of reaiming. whose 95/96 did you work on? do you think the 97-99 install of HIDs would require less reaiming? |
His own.
And would 97-99 require less reaiming? Eh, they still need to be reaimed. How long it take kinda depends on how good you are at reaming them. Originally posted by j_bryan medic- whose 95/96 did you work on? do you think the 97-99 install of HIDs would require less reaiming? |
isnt the only company that makes low/hi beam hids beloff so far? they're back up to around 1000 too as far as i've heard.
The concept was that I wanted to get excellent light output and be able to see what most see on highbeam, while not blinding oncoming cars. To do this, my highbeams are aimed so that they are to the right(passenger side) and below where most headlights are.
Tired of looking around for bulbsss
OK!! I'm gonna get HID!!
How much do you think I should spend? I don't mind buying used one.. What do you all think of this one on ebay: http://cgi.ebay.com/ebaymotors/aw-cg...591533&r=0&t=0 cheap? expensive? What's the different between brand?? osram HID, philips HID, vision HID? Which one is the best..... check this too: http://cgi.ebay.com/ebaymotors/aw-cg...558938&r=0&t=0 that one claims to have high beam......... |
Talk to member 97GLES... he sells an HID kit for $425.
What do you think of this???
Re: What do you think of this???
Originally posted by medicsonic The concept was that I wanted to get excellent light output and be able to see what most see on highbeam, while not blinding oncoming cars. To do this, my highbeams are aimed so that they are to the right(passenger side) and below where most headlights are. |
Originally posted by j_bryan sounds like a good idea. did you ever think about swapping your 95/96 headlights with the 97-99? i thought I've read that the 97-99 work better with the HID kits. also that they look better. can anyone confirm? I've been thinking about it... |
Originally posted by j_bryan sounds like a good idea. did you ever think about swapping your 95/96 headlights with the 97-99? i thought I've read that the 97-99 work better with the HID kits. also that they look better. can anyone confirm? I compared my friends Volvo C70 (glass head light) with aftermarket Philips HID and acura TL's HID (relfective head light)......... The volvo's HID is alot brighter..... but it doesn't look as nice... as TL's........Blurry........but very bright The mercedes Benz also use glass head light HID, and I personally thing it's brighter than the one with reflection head light..... The 95-96 use glass light and 97 above use reflection. Projector Light works the best with HID... like BMW and Audi |
| All times are GMT -7. The time now is 07:01 AM. |
