Ebay Knock sensor's - any good seller's out there
Hello,
I have had mixed results with ignition coils. Bought 6 from a guy called Airflowtech - they worked for a week and crapped out - very shoddy construction - which was not apparent when new - but the heat of the engine sure made the flaws obvious. Bought another 6 from a guy on ebay called golf6daysaweek - must say, much better experience. Very good coils - truly OE. Now, I am seeing a price range of 20 USD to 120 USD on ebay for the knock sensors. Anybody has experience with which seller is good (golf6daysaweek does not have knock sensors, or I would have bought from him/her). |
most people on here will probably tell you that all are decent and I would have to agree. I have $25 KS and it works great. just buy the cheapest one. it should work just fine
Originally Posted by tosheto
(Post 7312580)
I paid $45 for mine on ebay, and it was OEM in sealed NISSAN packaging, so some sellers to sell OEM KS on ebay. You should be fine. Here is who I got mine from http://cgi.ebay.com/ebaymotors/GENUI...#ht_6048wt_923
Do we need the KS? My check engine light is on for it but car still runs fine. and now i know i can get them off ebay if i need it ill get it.
What does the KS effect? |
Originally Posted by TravisCadello
(Post 7313118)
What does the KS effect? Search! |
I just made sure to get one that said new and oem. I paid about 50-60 shipped and haven't had any problems.
(Post 7313118)
Originally Posted by Shift_Nismo
(Post 7313270)
When the knock sensor is out, the ecu goes into safe mode. The car will run "fine", but you will have alot less power. The KS is a ghost code, it doesnt trigger the CEL.
:sprint: KS wont trip CEL. U may have another issue there |
to the OP did you get a chance to order one yet?
We need a bigger Search Button. |
Yes,
I have ordered one from Deutschepartsusa (ebay seller). -- to the poster who indicated that KS would not trip CEL - That is correct, I don't have a CEL. However, the smog place indicates I am having timing issues (KS will retard timing), and therefore, I am trying to see if replacing KS fixes the timing. Thanks, |
Originally Posted by mbhang
(Post 7315215)
Yes,
+ 1 for Deutcheparts. Have mine in for 2 months with no problems.
Excellent! I bought one from Deutcheparts and am awaiting it's arrival, this makes me much happier knowing it other people have used this seller! :D
Just finished replacing my knock sensor on my 98 maxima. I bought on ebay for $48 from tennesseeautosales. Its oem so you have piece of mind. And it works great. I notice the difference in power
I had gotten mine off there way back in the day. Just look for ones that are oem.
I thought it would trigger CEL. when i checked my CEL it had a few codes.
1-knock sensor 2-crankshaft position sensor 3-idle air control valve (Fixed) Does anyone have a pic of where the KS is at? i want to change it but have no clue where it is at. |
(Post 7354758)
1-knock sensor 2-crankshaft position sensor 3-idle air control valve (Fixed) Does anyone have a pic of where the KS is at? i want to change it but have no clue where it is at. look in the stickies for a how to |
(Post 7354843)
under the intake manifold.
(Post 7355810)
you serious? so pull off the upper intake manifold?
I will be pulling the lower intake when I do mine shortly since the upper is coming off to do an injector and I am half way in there anyhow. |
I recently bought a ks for my 97 Maxima SE on eBay for $22 shipped. Just installed it today. Have the cuts and scrapes to prove it. Here's who I bought it from:
chandlermotorsportsinc No problems. Looks identical to the oem I removed. Cheers |
| All times are GMT -7. The time now is 06:10 PM. |
