Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Rims don't fit (https://maxima.org/forums/4th-generation-maxima-1995-1999/605216-rims-dont-fit.html)
Godfatherrr Dec 28, 2009 09:27 PM
Rims don't fit
Need some help. I been having trouble with finding 17" rims that fit my 95 maxima.
I have a budget of 400 without shipping.
Please help
EnervinE Dec 28, 2009 09:31 PM
http://forums.maxima.org/wheels-tires-45/
Also check craigslist. You need a wheel with a bolt pattern of 5x114.3 (also known by some as 5x4.5)
ChrisMan287 Dec 29, 2009 05:36 AM
Remember to check the center bore as well. It has to be at least 66.2 IIRC.
Oldgeezer Dec 29, 2009 07:09 AM
Do you know what kind of wheels you want? I am assuming you want something aftermarket, correct?
You could also try and see if there is anything over at tirerack.com. I have heard they are priced someone fairly.
aackshun Dec 29, 2009 09:17 AM
+1, I've seen decent rims @ $99 each.
Godfatherrr Dec 29, 2009 10:31 AM
I haven't had any problems with the bolt pattern. The struts gets in the way of the tire.
Godfatherrr Dec 29, 2009 10:32 AM
ya i looking for aftermarket.
Godfatherrr Dec 29, 2009 10:40 AM
Explain to me more about the center bore, i have no idea what you talking about and i thinks thats my problem. lol
Godfatherrr Dec 29, 2009 11:00 AM
Fond these rims on ebay that i like. i just need to know that their going to fit, and not hit the wheel well, and not hit the struts?
http://cgi.ebay.com/ebaymotors/17-Ri...item2a037f77b0
BenStoked Dec 29, 2009 11:04 AM
center bore is the diameter of the hole in the middle of the wheel. if it is too small, the wheel won't bolt all of the way down (and can get crooked, and wobble as you drive, if you try anyway).
the problem you seem to have is the offset is too high. that is the distance from the mating surface of the brake hat to the center of the wheel. too high, and your wheel hits the strut. too low, and your wheels stick out.
more info on wheel fitment:
http://www.discountedwheelwarehouse....ment_Guide.cfm
Conrad283 Dec 29, 2009 12:04 PM
Go onto ebay and type 5x114.3
96i30azn Dec 29, 2009 01:19 PM
Some people pay a lot for this - good wheel spacers are $200+/axle. Oh yeah, offset is how far the mounting surface is from the center of the wheel. Spacers decrease offset which you need if your wheels are hitting the strut. I believe our stock offset is 45mm with variations for SE and i30t models. You should check in the wheel/tire forum for more details. Here's a link to the sticky if you're too lazy:
http://forums.maxima.org/tires-wheel...-will-fit.html
Snypa Dec 29, 2009 04:46 PM
I have some 18's selling in Daytona if your interested.
http://forums.maxima.org/general-max...iced-rims.html
Coolsaber57 Dec 29, 2009 05:37 PM
Those should be fine. They are actually close to the 5th gen SE wheel size. IIRC, those are 45 mm, where yours are 40mm, so they'll stick out just a little bit more.
internetautomar Dec 29, 2009 06:17 PM
45 offset will pull them closer to the strut housing not further out.
ChrisMan287 Dec 29, 2009 06:22 PM
Very true.
Lower offset = closer to fender.
Higher offset = closer to strut.
Godfatherrr Dec 29, 2009 07:14 PM
Originally Posted by ChrisMan287 (Post 7358320)
Very true.
so do you still think they'll fit?
Godfatherrr Dec 29, 2009 07:15 PM
It says the off set is 40 not 45?
ChrisMan287 Dec 29, 2009 07:30 PM
40mm offset will fit fine if the bolt pattern is 5x114.3 and the center bore is at least 66.2 :nod:.
Coolsaber57 Dec 29, 2009 09:22 PM
You misread my post.
45 is the OEM 5th gen SE wheel, 40 is his ebay wheel.
MaxiNone Dec 30, 2009 07:18 AM
^^^they should fit cause even though the offset is 40 the width of the wheel is only 7in...
MaxiNone Dec 30, 2009 07:34 AM
hopefully this can help you understand offset and wheel bore.
http://i48.tinypic.com/bfqo8j.jpg
http://i46.tinypic.com/wlaf6g.jpg
EMC2 Dec 30, 2009 12:09 PM
A quick fitment question
I'm looking for a set of used winter rims for my '97 Maxima and have come across the following:
- a set from a 1989 Mazda RX-7
- a set from a 1992 Infiniti Q45
Will these fit my Maxima? They are both 5 x 114.3
MaxiNone Dec 30, 2009 01:32 PM
from what i have heard and remember reading the wheels the FC wont fit cause the center bore isnt big enough. as for the Q45, they will fit...
Fasteddie01 Dec 31, 2009 07:52 AM
Hey there - Both will fit, but the Mazda will be a little loose (1 mm); I tried rims off a 626 and had a slight high speed vibration. I don't know if they make a 1mm adapter ring, but if your hubs are cleaned (no rust) you'll have that slack. Also, the centre bore may not allow dust cap to fit inside rim (may depend on rim design- 626 was too small), thus not allowing proper mounting against hub. I had to remove the rear dust caps (front doesn't have caps). If you can deal with these issues and get them for a good price, they'll work.
hynes66 Apr 9, 2010 09:29 PM
I am looking for four decent chrome rims for my 95 maxima. Want to keep it under $500... anybody?
dkillahster Apr 10, 2010 11:34 AM
ummm?
welcome to the .org?
:gotme: :laugh:
Mr.A32ftw Apr 10, 2010 11:43 AM
http://forums.maxima.org/washington-...rts-cheap.html post#6
SiathLinux Apr 10, 2010 12:32 PM
Washers on each lug bolt before install of wheel fixes the 1mm issue... though I thought that the center bore helped to 'center' the wheel...
