Digital Climate Control To Manual Climate Control
i Have a basic '95 max, i recently ripped out some things from a GLE model max, i think it was a '97. One of the things i took out was the Digital Temperature control unit, I tried to put it in my maxima but the connector in the back was different and on my maxima there were 3 connectors, is there anyway i would be able to hook this up? or this is impossible i would have to change other things too?
Re: Digital Climate Control To Manual Climate Control
I have no idea why people would want to go from the manual to the climate control. I have the climate control, and I hate it. The only thing it's good for is turning on the heat when the engine gets warm. Other than that, it sucks. I loathe how many button presses it takes to get my defrost on without A/C.
Licensed to Spell
Re: Re: Digital Climate Control To Manual Climate Control
Originally posted by jargoone
Get your subject right. It's backwards. I read it because I would like to do what it actually means.
Are you MAD?! I LOOOOVE my electronic climate control! What's the problem jarg.? To run the defrost without the compressor it's <ECON>, <MODE>x4 real quick. Less than a second. My only complaint is the lack of outside temperature display. But other than that, it rules.
Re: Re: Re: Digital Climate Control To Manual Climate Control
it takes me 1 button push the defrost
Re: Re: Re: Re: Digital Climate Control To Manual Climate Control
I dunno. Just don't like it. It just takes more work to accomplish what I want. Maybe I'll get used to it, but it's been 6 months and I don't like it anymore than I did at first.
SuDZ
Licensed to Spell
:o)
If you guys are having trouble with it my guess is you are not using it correctly. I think what you're trying to do is use an automatic like a manual. Yes, in that case, it will take more button pushes to get the same result. But if you use the auto feature, you press one button: auto/on and you're done! The electronic climate control does the rest! Anyway, e-mail me if you have any specific questions or want to discuss it. I'll try to share what I know.
Re: :o)
* I don't like to run the A/C with the defrost unless I have to
* I often like warm air coming out of the dash vents
* I sometimes just want the fan on high because it's stuffy and the air in my face feels good
Accomplishing these things on the ACC often requires hitting one button several times, while watching the display (instead of the road) to see when I need to stop. Most manual systems require the pressing of one button for the air direction, which is a very short distraction from driving. Sliders or ***** for fan and temp don't require looking.
In my opinion, ***** and sliders are better for climate control for the same reason analog gauges are better than digital readouts -- the motion is more intuitive. Maybe I'm picky, but that's how I like it.
Licensed to Spell
Re: Re: :o)
I can use it "correctly", my problem is that the automatic settings are seldom what I actually want. For example:
Sounds like you would benefit from a manual system. But be grateful, although they may several button pushes away, at least the manual overrides are available to you!!! My Audi sucked! No choice for heat out the vents, only 3 fan speeds, etc. Besides, isn't it fun to be able to display '69' on the screen?
Re: Re: Re: :o)
I love turning on the heat right away, with a cold engine, and the car will not feed me heat until it has it (won't blow cold air).
Hey Im just reading ole notes u guys sent in if u stil lhave the ACC and didnt bother doin te install would u be interestd in sellin it?? I would like to do the manual to auto if not how much did u get urs for and which junk yard did u get it or were did u get it Thanks Hit me bk at babyc1999@hotmail.com
tseng1023
10-15-2015 08:30 AM
DC_Juggernaut
09-28-2015 04:07 PM
