For those of you who have done a clutch job....
Hey guys,
How many of you dropped the crossmember? I am just curious because if I need to do a clutch in the future, I fear that if I take the the bolts off on the crossmember/core support, that I will never be able to get them back in, and be stuck doing a core support at that moment. I plan on replacing the core support soon too. So was anyone able to access the shift linkage bolts without dropping the crossmember and successfully do the clutch job without removing it? Thanks guys, Matt |
go for it. Totally doable without dropping the cross member
i did it last year didnt remove cross member didnt remove exhaust either pretty easy helps if u have some help i had none it took me bout 4 hours i had impact tools so that helped and a garage
Okay cool. I've done 2 clutches on this car already and both times I took the crossmember out. I was pretty sure the 2nd time I did it I realized how it seemed unnecessary, but I just haven't had a chance to get under the car to look.
i never touch the cross member, i can get it done in 2 hours now.
Originally Posted by 99BlackMaxMS
(Post 7993063)
You'll be fine not removing the cross member with a manual.
(Post 7992989)
Hey guys,
Originally Posted by luke95gxe
(Post 7993074)
i believe that bolt on the shift linkage is a 14mm and u can get a off set wrench and it comes off fine seems tight but it is ttaly doable
Originally Posted by 97SEdriver
(Post 7242956)
Everyone b1tches about the hard to reach bolt on the shift linkage support, do yourself a favor and get one of these.
http://i204.photobucket.com/albums/b...r/IMG_5667.jpg offset box wrench, $7-8 even if you buy craftsman. and Evapo-rust works...use it or something like it to soak every nut, bolt, and whatever you can, makes life easier putting things back together. http://i204.photobucket.com/albums/b...r/IMG_5681.jpg |
Ratcheting wrenches work wonders.
Spare 12mm, IIRC, ground down for better access to the drain plug. |
Don't have to remove the crossmember. Done it bout 4 times and never messed with the crossmember. With the right tools, its easy.
I didn't drop it, but loosening the two crossmember-frame bolts at the front just a half inch or so was the only way to get the lower bellhousing bolts out. Otherwise they were trapped in by the crossmember. The clearances were so close though that you may not run into this problem.
© 2024 MH Sub I, LLC dba Internet Brands
