95 throwin some codes
Well Ill start out with postin the codes I just pulled
0102 1103 0102 I believe is the MAF sensor The ECU decoder explains 1103 as Improper shifting to first gear (A/T) now for some history about 6 months ago my engine stalled on the highway while coasting into some slow traffic. since then the problem has gotten progressively worse, mostly stalling at stop lights in gear, but now it stalls almost everytime I get in the car to go somewhere. I tried cleaning the maf a few months ago and I replaced the fuel filter last week before finally trying to figure out how to pull the CEL codes. Now Im relieved that the stalling issue is most definitely coming from the MAF, but where the F is this trans code coming from? My CEL just came on like a month or two ago, well after I cleaned my maf. is the 1103 a ghost code that could have been there since I bought the car over a year ago? |
Improper shifting?? Looks like you gonna have to start shopping for a tranny or a donor one to get the solenoids from.
What color is your tranny fluid? Does it have bubbles in it? Is it filled up? |
haha I wouldnt even know where to start lookin for the transmission fluid reservoir.
theres no reservoir, not sure with the autos but you remove the speedo sensor on the manuals. one 10mm bolt and just wiggle the thing out. you have to remove air intake assembly to get a better look. be careful with the sensor, its plastic.
Originally Posted by TheRandish
(Post 8123339)
Originally Posted by SHIFT_maxboost
(Post 8123355)
Use the fill plug, that's what it's there for.
(Post 8120357)
0102 1103 0102 I believe is the MAF sensor The ECU decoder explains 1103 as Improper shifting to first gear (A/T) now for some history about 6 months ago my engine stalled on the highway while coasting into some slow traffic. since then the problem has gotten progressively worse, mostly stalling at stop lights in gear, but now it stalls almost everytime I get in the car to go somewhere. I tried cleaning the maf a few months ago and I replaced the fuel filter last week before finally trying to figure out how to pull the CEL codes. Now Im relieved that the stalling issue is most definitely coming from the MAF, but where the F is this trans code coming from? My CEL just came on like a month or two ago, well after I cleaned my maf. is the 1103 a ghost code that could have been there since I bought the car over a year ago? This trans code generally indicates a serious problem within the trans, requiring rebuild or replacement. If the trans seems to be working properly, clean or replace the MAF, reset the codes, keep driving it. |
Your talking bout the half inch drive plug on the front of it, causing it to pour out?
(Post 8125049)
i just gotta lol at this, not to mention we have a SEARCH function that never seems to get used except by older members.
(Post 8125280)
Originally Posted by pmohr
(Post 8125284)
:wall:
© 2024 MH Sub I, LLC dba Internet Brands
