Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Can't get axle out... (https://maxima.org/forums/4th-generation-maxima-1995-1999/640994-cant-get-axle-out.html)
DBear Oct 22, 2011 12:09 PM
I'm replacing my front right (passenger) axle. I got the knuckle off easily enough, but I just...can't...get...the axle to come out. I've tried prying with my Mother of All Screwdrivers, but there really isn't a lot of good leverage down there. I'm prying against the small lip inboard of the inner boot, so it's a deccent pry point. I've got some room to whack on the handle of the screwdriver with a rubber mallet, but it doesn't help. I've tried yanking on the axle itself (between the boots) too. There's about an inch of give, and then it feels like I'l pulling on the whole axle, but that isn't doing the job.
I've already spent an hour on this part alone. Anyone have any suggestions on how to get this thing out??
ATTappman Oct 22, 2011 12:12 PM
Did you remove the three bolts on the carrier bearing bracket?
DBear Oct 22, 2011 12:29 PM
No, since I don't even know what that is.
DBear Oct 22, 2011 12:30 PM
BTW, it's an AT.
DBear Oct 22, 2011 12:35 PM
Well f*** me for being an idiot. I see it now. I thought that was part of the axle assembly, but I see where it comes off. I'll try that. Thanks.
315max Oct 22, 2011 02:01 PM
take the three bolts off that connects the carrier to the axle. if you still ant get it out take out the three bolts that hold the carrier to the car. its a b**** to get them apart due to corrosion and old age
JNCoRacer Oct 22, 2011 02:29 PM
Thats why I always put grease on the mating surface where the carries bearing slides through.
DBear Oct 22, 2011 02:50 PM
I can't even get in there to get any leverage on the bolts. It shames me to say it, but I think I'm going to have to punt on this one.
315max Oct 22, 2011 03:38 PM
you can do it. its a pain the first time, i kno from experience. just keep working on it
Br0nz Oct 22, 2011 05:05 PM
yup just finished this repair, i had to use an air chisle no way i couldve gotten it otherwise!
Snypa Oct 22, 2011 09:36 PM
Air chizzle did it for me too...so much that I only have 2 bolt holes instead of 3. Glad you got it though. !
Br0nz Oct 22, 2011 11:27 PM
yeah it was all going smooth like 20 min in i had all three bolts out of the carrier bearing but hrs later i still couldnt budge the axle. so i finally called my bro to bring me a bigger compressor and the ingrosol rand air chisel!
op if you have airtools i strongly suggest investing in a good air chisel
air chisel > *
Snypa Oct 22, 2011 11:39 PM
air chisel > *
I think doing it by hand would work too, big chisel + Big hammer + hammering Muscles.
Br0nz Oct 23, 2011 04:43 AM
theres no room to get a good swing i tried that, i mean im sure i CAN be done but.. i had access to a tool that hits at like 30/sec!!
