Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Ball Joint Bad? (https://maxima.org/forums/4th-generation-maxima-1995-1999/642930-ball-joint-bad.html)
JEFF6898 12-10-2011 09:28 AM
Ball Joint Bad?
Went and had 2 front tires installed. The guy tells me I have a bad drivers side ball joint. went home jacked up the car and and there is no loose movement when I move the tire up and down or back and forth. Think they were trying to sell me something I didn't need? Is there another way to check? Car seems to drive good although It feels like it pulls to the right.
MAXIMA_STYLE 12-10-2011 09:45 AM
ball joint boot cracked?? does the car shake even the slightest when driving?? is it the original balljoint??
JEFF6898 12-10-2011 10:47 AM
Has a slight vibration and bad pull to right unsure if cracked and as far as I know it is the original ball joint.
anomaly117 12-10-2011 01:38 PM
the ball joint would be leaking and the free play would be felt in the camber. you should be able to hear a knock and the vibration will be worst when you turn the car in the opposite direction of the bad ball joint.
JonBlz 12-10-2011 02:01 PM
When will you hear a knock under what condition
smash 12-19-2011 02:47 PM
Is there a DIY on how to replace these? Just the ball joints, most people tell me to do the whole arm. But $150 VS 20-30$ is a big deal to me.
skarface08 12-26-2011 05:14 PM
http://www.youtube.com/watch?v=yTIePKbH3hY
skarface08 12-26-2011 05:15 PM
he talks about the ball joint as well, also check out his other videos for your Maxima.
burts 01-01-2012 02:33 AM
Sometimes you wont get play from moving the wheel up and down like, sometimes you have to stick a pry bar in there and give it pressure where it needs it to see and feel the play..
CMax03 01-01-2012 02:58 AM
Hit a bump and see if there a rapid vertical vibration or place a prybar, 2x4 under the front wheels while jacked up, work the wheel up and down 12 o' clock to 6 o'clock and feel the balljoint for play..... tierods are a lateral movement if you shake the wheel from 3 to 9 o'clock....and feel your outer and inner tierods for play!
Jessica1988 01-01-2012 06:25 AM
Hope you went well into 2012 !
ivokanivo32 01-18-2012 08:35 AM
Need help with aftermarket ball joint installation . I cannot put it back in all the way with a bjoint press. What are my options?
svezarov 01-18-2012 12:07 PM
I have had this issue before. Had to use dremel rotary tool to enlarge the whole (in this case in the control arm). After some dremeling it went in.
bobflood 01-19-2012 07:13 AM
Another trick - put new ball joint in freezer overnight. It will shrink slightly and may slip in easier. Worked well on my Explorer.
raroz28 01-19-2012 03:28 PM
The two things that these guys always try to sell me and everybody is - ball joints and sway bar links.
If you can't feel or hear that the ball joint is bad and you checked it out yourself then it's probably fine.
© 2024 MH Sub I, LLC dba Internet Brands
