Warpspeed Y; Bee's in a can delete?
Is there anything that can be done to get rid of this god-awful sound?
Does a crappy, crush bent, restrictive exhaust make this worse? Better yet, would a nice, high-flow, mandrel-bent exhaust do anything to calm these damn bee's down? |
From what i've read in the past, the longest resonator possible helps quite a bit. The one's from Magnaflow seem the most popular.
Or another option would to be to turn up the volume on your stereo. |
Bad flex section. Replace it.
Originally Posted by Bonka
(Post 8356029)
(Post 8356029)
(Post 8356024)
Replace flex I did a shorter one mine 3inch and have straight pipe back ill post a link to it or search on YouTube Linda Lohan maximal
Lindsay Lohan
Originally Posted by wirelessdude04
(Post 8356035)
Have them send you another flex section, tell them it's defective.
Everyone on here has this problem from what I've read, what causes this? Surely they can't all be defective.
Originally Posted by comingup
(Post 8356049)
Just call them up & tell them about your dilemma |
Originally Posted by Gismo-T
(Post 8356051)
Bad batch of flex sections
what classifies them as a bad flex? I have a budget Y. Inspected it a few times, looks perfectly fine. I have the bees in a can in 1st gear. cattman exhaust, long resonator, long magnaflow 19'' muffler. 2.5'' piping, custom test pipe. |
Originally Posted by VisciousMo
(Post 8356054)
I have the bees in a can in 1st gear. cattman exhaust, long resonator, long magnaflow 19'' muffler. 2.5'' piping, custom test pipe. I had a Budget y for 4yrs. no problems I've just heard of bad batches of flexes, that's all. |
(Post 8356054)
Warpspeed and Stillen units had this problem before.
You can try wrapping the flex with exhaust wrap, but if you're in a wet climate I wouldn't recommend it and if Warpspeed won't do anything about it, either replace it or live with it :/ |
Bees in a can? Would you guys classify or describe the noise as annoyingly loud exhaust drone?
If its coming from the y-pipe, then the flex section is either faulty or a bad design from the manufacturer. Install an OEM flex and listen to the noise go away. EDIT: TBH, up here in MASS, loud exhaust is a no no. For this reason, i have yet to get a y-pipe. |
I think thats the sound of the exhaust valves
I had a warpspeed, sounded like an angry swarm of bees....
Exhaust leaks everywhere. Loud as ch1t. Performed like a champ though :cool: |
as much as people will not agree with me - i think its because the y-pipe is un-equal length.
I have a stainless warpspeed y-pipe, cattman catback and testpipe. The cattman resonator went bad so I deleted it with a straight pipe, that was a mistake as it brought on the bees and raspyness. I later wrecked my flex section and replaced it with a new one that warpspeed sent me. No sound change between the two flexes, if any the new one was better. Got fed up of the ricer sound and welded in the longest magnaflow resonator I could find, Fixed the rasp and killed the bees. I suggest you try a new resonator.
Magnaflow is ideal for those who don't want to much noise but still want the performance. You never really know exactly how something will sound on your car until its installed. Ive never actually heard this "bees in a can" sound so commonly referred too. I have heard crappy exhaust nots from people simply putting a cheap muffler on the end of a stock header back. Its more of a hollow exhaust. Not a deep tone like it should be.
(Post 8356029)
(Post 8356033)
YUP
Originally Posted by joesae01max
(Post 8356716)
I had a WSP y-pipe on my car for something like 8 years and did everything imaginable to get rid of that rasp. First, I kept the stock cat-back. Still had rasp. Eventually got a Budget resonated b-pipe and 2k Max muffler, still had rasp. Replaced my straight pipe with a resonator, still had rasp. Replaced the frayed flex section on my WSP y pipe, still had rasp. Of all the things I did, replacing my test pipe with a Megan resonator made the biggest improvement. My flex section was pretty frayed on the inside, and I replaced it with the new-style WSP flex, but it made almost no difference. But do you know what did fix it? Equal length Cattman headers. They are about 7 years old and the flex isn't prefect, but it isn't frayed on the inside, so I don't really care at this point. There is still a touch of rasp when going WOT, but there is NONE when letting off the gas at 4000+ rpm. Damn near perfect. Want to get rid of your rasp? Buy that used Stillen equal length y pipe that just went up for sale or get some equal length headers! |
(Post 8356777)
DING DING DING!
But do you know what did fix it? Equal length Cattman headers. They are about 7 years old and the flex isn't prefect, but it isn't frayed on the inside, so I don't really care at this point. There is still a touch of rasp when going WOT, but there is NONE when letting off the gas at 4000+ rpm. Damn near perfect. Want to get rid of your rasp? Buy that used Stillen equal length y-pipe that just went up for sale or get some equal length headers! |
(Post 8356748)
these are two BS assumptions...when i first did the warpspeed ypipe install on my car i had it straight piped to my cattman axleback...i had the bees in a can. what did i do? i purchased a cherry bomb resonator, got rid of it. get yourself a resonator...just a word of advice, cherry bomb will not last that long, but between the sound of hte cherry bomb and the magnaflow resonator, the cherry bomb sounded better. but i wanted longevity, so i replaced it w/ a magnaflow
OP, I assume you are stock other than the y-pipe. Is this correct? EDIT: If you dont have a resonator definitely get one installed, the longer the better |
you are unsure yourself as to what he has...yet you reiterated what i just said... :rotz:
Originally Posted by larso1
(Post 8356815)
So are we talking about unequal length headers or an unequal length Y-pipe? I see both mentioned interchangeably. Sounds like mixing apples and oranges.
well obviously not having any sort of resonator is gonna make the exhaust loud.
Once the entire setup is known then more insightful suggestions can be given. The OP wasnt very descriptive. |
(Post 8356840)
I think anything unequal length will give you rasp.
I agree. Problem is, once u have it installed, its installed. |
Hrmm... I feel like putting on a warpspeed y-pipe to prove everyone wrong here...
Anyone has one sitting around? |
all i'm saying is you get a rasp w/ warpspeed, at least i know about warpspeed, granted you run straight pipe and it'll be eliminated w/ a resonator, any other scenario i can't claim, but i no longer had bees in a can when i installed my resonator
Really all of us are making assumptions, especially if the OP doesn't provide a sound clip of the actual noise he's referring to so we know what he's talking about especially since bees in the can and rasp has been used interchangeably in this thread.
If it's the actual exhaust note you're complaining about than yes it's due to the unequal length y-pipe. On it's own, it made my car sound like a Cavalier. It's a low, uneven grumble but nothing like bees in the can. Each of them produce completely difference sounds. |
Originally Posted by aackshun
(Post 8356865)
Anyone has one sitting around? I had that WSP y pipe on almost every setup imaginable....in this order: On my 95 GLE with an un-resonated 2.5" b-pipe and Stillen muffler: Loud and raspy/serious bees in a can On otherwise stock (current) I30: Quiet, but I think there was still a little rasp on over run. I30 with test pipe and 2k muffler: Kind of nasty, the unresonated test pipe was not a good idea. Test pipe, Budget resonated B, 2k muffler: A little louder, more rasp Resonated test pipe, Budget, 2k: Significantly lowered rasp levels but no other real difference in volume. New style flex section in WSP y-pipe, resonated test pipe, Budget, 2k: Almost no difference. My flex wasn't torn, but it was frayed badly inside and out. I'm skeptical that a bad flex section is the usual culprit for rasp in our cars. I think 90% of rasp is caused by unequal length headers/y-pipes. If only I had fully realized this earlier I probably would have gotten headers earlier! |
(Post 8357221)
Exhaust sounds smooth when you keep the OEM y-pipe but swap in an aftermarket catback (eg: SP2/WS2). Once the y-pipe was replaced it messed up the exhaust note. If y-pipe owners have issues with the sound you could have an exhaust shop extend the piping to make it equal length. |
flex failure isnt going to cause a rasp, its going to cause more of a exhaust leak sound
(Post 8357221)
I'm not saying that the flex section causes rasp, I'm saying non-high quality parts cause it :D |
Even tho its beaten to death, I love exhaust threads. They are the most fun. :)
When i hear unequal length headers, I think of turbulent flow. Turbulent, fast flow plus poorly designed flex section would result in rasp. in order to decrease that rasp, i would think u either need to smooth out the flow or install a flow resriction to slow it down a bit and decrease its energy. installing a stock muffler should eliminate much of the rasp, resonator will take care the rest. |
(Post 8356054)
(Post 8357221)
I did, but I sold it :)
| All times are GMT -7. The time now is 04:02 PM. |
