oil extractor
will the dip stick oil hole be big enough to use an oil extractor on a 99 Maxima?
why?
I usually use the oil pan drain bolt/screw to take the oil out..
We need to know what for though :scratch:
The answer to the OP is "probably", just depends on how big the extraction tube is compared to the dipstick tube. But, as everyone else has said, why would you want to do it that way????
Many people seem to be going to that method, see it a lot on BMW and MB forums.
Yamaha outboard engines show an oil extractor in the owners manual (and yes they have an easy to get to drain plug, but use the dipstick tube to suck the oil out) |
Why fight gravity?
Beyond unnecessary.
(Post 8646745)
Beyond unnecessary.
you can use the drain bolt?? I always just undo my lower pan completely... thx for the tip
Originally Posted by kasso28
(Post 8647314)
(Post 8647314)
Originally Posted by andrewmac
(Post 8647425)
You mean you can just take the pan off to the drain the oil? Jeeze, I've been taking my engine out and flipping it upside down and letting the oil drain out from the dipstick hole. This will make things a lot faster.
Using this little accessory makes draining the oil via the oil pan plug real easy. And you won't scratch the car's roof or have your wife/gf screaming at you for getting grease on the bed's comforter when you use it to roll the car on.
http://toolmonger.com/2007/09/07/eastwoods-tilt-a-car/ |
(Post 8647314)
you guys are hilarious.....:coffee:
(Post 8647528)
Originally Posted by stanltod
(Post 8647715)
I think that is the same rig they used on the Back to the Future ride at Universal Florida to give the flying effect. So, am I the only one that removes my valve covers every oil change and hoses down my cams with soap and water to make sure I get every drop of old oil out of the block? Likewise, I lubricate the inside of my radiator hoses with synthetic oil to ensure the water can flow thru with no resistance. ;)
© 2024 MH Sub I, LLC dba Internet Brands
