Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   How many LEDs do I need if I'm changing the gauge lights? (https://maxima.org/forums/4th-generation-maxima-1995-1999/658294-how-many-leds-do-i-need-if-im-changing-gauge-lights.html)
zubi23 Nov 19, 2012 10:30 AM
How many LEDs do I need if I'm changing the gauge lights to blue? So far I bought 6, does anyone know how many lights are behind the cluster?
Also, how do I change the needle to a bright red led, is there a light bulb for that?
Maximus92 Nov 19, 2012 10:43 AM
5. but no, you cant just buy bulbs for the needles.
tigersharkdude Nov 19, 2012 10:44 AM
refer to LED link in my sig.
Max139617 Nov 19, 2012 11:01 AM
5 leds, t10 5smd
tigersharkdude Nov 19, 2012 11:20 AM
OP, what year is your car? 95-97 use different size bulbs than 98-99
Originally Posted by Max139617 (Post 8667773)
5 leds, t10 5smd
those only work for 95-97.. they DO NOT work on 98-99
2brosgixxer Nov 19, 2012 12:07 PM
1 Attachment(s)
OP, these are the "cool white" leds in my 97. They are pretty blue but just to give you a reference point. Also, if you want red needles, take the factory paint off the UNDERSIDE of the needles by using nail Polish remover or something similar. You don't need to take the needles off to do so, but be careful that you don't get any of the remover on your cluster. Then, what I did, was use a red permanent marker on the UPPER side of the needles. Works good with the cool blues. You can also get some "Testors" model paint and do the same thing but the marker worked great for me. Just make sure you put the marker on the upper side of the needles...it does not look as good if you do it on the underside.
Attachment 38775
Max139617 Nov 19, 2012 12:37 PM
This is true. Slipped my mind lol.
Anyway OP you should've searched countless threads on this subject. Matter of fact just look at TigerSharkDudes sig
