I just put on a oil pan gasket on my 98 max due to oil leak there was no gasket on at all which was odd but anyways. How long do I have to wait to my oil back in a test drive?
That's because the oil pan is sealed by RTV silicone not a gasket :hat:
Hope he scraped off the old gasket before he put the new "gasket" on
1 Attachment(s)
Yeah I did I'm not a dumb *** just was trying to figure out how long I have to wait before I test drive my car after I reinstalled my oil pan. Out all the ppl in this forum I still get dumb *** responses
Attachment 2976 |
1 Attachment(s)
I would let the RTV set overnight before filling with oil and starting the engine.
You made it sound funny but anyway your answer is on the product you used. :) Some products have different drying times.
the first time I ever did an engine swap I put RTV on the lower oil pan and had oil in the thing within 3 hours. it never leaked.
VWs' use white RTV. At the dealership we didn't wait at all.
grey all day. Mechanics don't wait either.they do and send you on your jolly way. Last time I did it, I gave it like 3 hours before filling with oil and starting engine.
I actually let mine sit 24 hours before filling back with oil on a summer day. Seeing that its a bit colder, same time might be ok.
Thanks for all the replies Unfortunately after I reinstalled my oil pan my sister took my car -.- so now I might have to redo it do to a bigger leak
RTV has awesome instructions on the tube and packaging. Something like apply it wait 15 minutes until it's tacky reinstall and start engine next day.
Well now since I have to re seal my oil pan which is better? ultra grey only or ultra grey with an oil pan gasket
Why do you have to reseal it again? What does your sister driving it have to do with anything? Nissan didn't use a gasket, why should you?
Because she drove it 30 minutes after I reinstalled the oil pan and I was wondering which one would create a better seal
Originally Posted by anthony18
(Post 8677373)
Edited for ignorance.
There's still a leak and maybe VW are different and I'm referring to the lower oil pan but what do you mean by cork I have picture in the beginning of the thread i think it's just aluminum on steel
Did you clean the mating surfaces with alcohol or something to get it oil free? If you applied rtv on an oily surface it won't stick.
Originally Posted by asand1
(Post 8677378)
If you are referring to the the lower stamped steel pan, then yes it needs a gasket. If it is cork DO NOT use RTV, as it will chemically react and eat the cork. The upper pan does not use a gasket, just RTV.
Yeah I won't use cork I should just use ultra grey with no gasket because I'm getting a new car in a couple of months
since when does our lower oil pan use a gasket? am i going crazy? granted I haven't had the oil pan off a VQ in a few years but I don't remember there ever being a gasket in all the VQs I've ever torn down, assembled, worked on, etc.
the lower stamped steel oil pan has a gasket available at rockauto & etc. the mating surface between the block and the "oil pan" (as known to nissan) known as the "upper oil pan" around here, uses rtv.
OEM does not have a gasket for it. Aftermarket suppliers are making one for what reason, I don't know.
I'm only referring to the lower oil pan not the upper oil pan that's a different ball game there. I'm leaking everywhere but don't have the time nor funds to fix them so my car will be driven till It can't move anymore then ill part her out
(Post 8680892)
(Post 8679308)
I was looking through the FSM earlier today and realized my error. FSM does in fact call for RTV on the lower pan. I was speaking from experience in general auto repair. Usually stamped steel pans would have a gasket, the VQ does not. |
© 2024 MH Sub I, LLC dba Internet Brands
