More problems with my 1997 maxima. p0171 code
Old 09-07-2013, 11:54 AM
xkazik's Avatar
i know even know where to start now , i took my car for inspection and it failed , the guy tells me the monitors are not ready , i go to autozone to check my codes i get p0171 , i need to pass inspection in 30 days , whwre should i start ? so for buying a maxima from a maxima.org member, though the car wa cared for ended up i got screwed big time . . im not even sure where to start diagnosing this car anymore
xkazik is offline
Old 09-07-2013, 12:36 PM
Calden__003's Avatar
http://www.boredmder.com/ecucodes/in...1997&DTC=P0171
Starting there might help you
Calden__003 is offline
Old 09-07-2013, 01:00 PM
Phromethius's Avatar
I'd lean towards the O2 sensor going bad. Intake leaks might be easy to check off the list. THe next one down as a possible cause is the 02 sensor. Not a big deal but you have to get creative with some hand tools to replace usually. 02 sensor socket plus some channel locks or adjustable wrench should be enough.
Phromethius is offline
Old 09-07-2013, 01:38 PM
I know this isn't the same code, but when I got a P0170 code on my 95 max (similar to your P0171, both fuel system malfunctions) it was my O2 sensor that broke (well the mechanic did putting a bead on it for some unknown reason). I got it replaced and the code went away.
Old 09-08-2013, 10:40 AM
xkazik's Avatar
I will be changing my oxygen sensor today , hopefully if i can get it out on my driveway , bank one sensor 1 , hopefully this will solve my problem . if not i will report back
xkazik is offline
Old 09-09-2013, 01:55 PM
xkazik's Avatar
how long till the o2 is ready ? my heater is ready but not the 02 or the catalyst or evap , i need one more ready monitor to pass inspection ,
xkazik is offline
sctludwig
09-01-2022 01:32 PM
mvm062
11-30-2020 09:00 AM
nbstriker10
09-04-2015 04:26 PM
boomerbrian
09-04-2015 08:25 AM
crazyespn
09-03-2015 01:30 PM
Quick Reply: More problems with my 1997 maxima. p0171 code
