Will P01447 Evap code make my car run like sh!t?
Sorry for the long story. Hoping somebody might have a similar experience and might be able to help..
97' 5spd. with over 200,xxx miles on it.. Was driving along the other day and the car started bucking and shaking real bad. It was almost like it was going into limp mode. Ran fine under 2000 rpms but acted up over 2000 rpms. Shut it off and restart it and it would go away.. So I stop @ autozone and get them to throw a scanner on it and it comes up with P01447 EVAP control system purge flow monitoring. I get it home and jump on the org to lookup possible causes and I go back out and start checking some stuff out. I noticed that my strut tower brace had broken the small hose connection on the evap canister purge control valve. http://i1288.photobucket.com/albums/...ps0d2acb97.jpg From my engine moving around and the valve hitting my strut bar it broke the plastic nipple off and the hose was cracked too. So I replace the hose with one that was close in size but not as tight as the original one. I though it was fixed. The car was running fine until today. I had to take an hour drive and on the way down it was fine. It started acting up on the way back. When I pulled over and shut the car off and restart it, it would run good for 5-10 mins then act up again. It got progressively worse until finally I had to get off the highway before I got ran over by a tractor trailer.. Could something with the evap system or P01447 code cause the car to run this bad? Is it possible that if the evap canister purge control valve has a vacuum leak it would make it run like sh!t? (I did pull the little hose off when it was running good and it didn't seem to have any effect) I'll start going over the evap system with my FSM but any help would be greatly appreciated.. |
sounds to me like the MAF is on the way out
That was the first thing I though about before I got it scanned.. Maybe I'll try cleaning it..
I have a 1447 right now, and mine runs fine. YMMV. My thought would be MAF too.
I just cleaned maf with some crc. It started up and idled better then it as been.. Took a quick drive around the block and it started acting up again.
I'll see if I can grab some video.. |
Cleaning the MAF does not always resolve the problem. The fact that it did run a little better keeps the finger pointing at the maf.
P1447 is the big Dbag of the codes. I'm still dealing with mine. Good luck OP.
Here's a video. My phone was on my dash holder and it was trying to go uphill..
http://i1288.photobucket.com/albums/...ps1ce145bd.jpg |
Thanks for the help guys!!
It turned out to be the MAF. Local junkyard had one for $50 so I figured wth. It's running good now! :D Thanks again much appreciated!! |
Damn it just started doing it again!! :mad:
It's definitely running better with the maf from the junkyard but it just went into limp mode again.. Autozone has a new re-manufactured maf in stock but it's $215.. Should I try it? Worst case I could take it back to a different az and tell em it was the wrong part? No new codes either.. Would a bad knock sensor put it into limp mode?? It's been knocking and pinging alot more since this problem started.. |
P1447 can be lots of issues man. Google pmohr's a32 decoder. Click the link and see what issues you get.
Map/Boro switch Charcoal Canister Boost sensor Some more sensors near the charcoal canister |
Originally Posted by Fauken
(Post 8851267)
© 2024 MH Sub I, LLC dba Internet Brands
