Idle control valve
Idle control valve
95 was having trouble starting and exhibited a rough idle. The code came back as a P0505 which is the idle control valve. The shop says the part is $350 and labor about $100.
I tried searching on Courtesy Nissan to see if the part was cheaper there, but I can't find this part.
Can someone help me find it?
IACV/AAC valve
Product SKU: 23781-A32B001
http://www.courtesyparts.com/23781m-...ml?cPath=1783&
Pricey stuff, check it out maybe it's only bad connection.
I wanna check as this confusion has happened before
this is a "P"0505 via the ODB2, not a "0505" from the Check Engine light correct? The 0505 is an "All Clear" or no codes available in the system.
http://forums.maxima.org/esp_search....=0505&type=gcs
97_GXE
20
09-17-2015 08:12 PM
lrb6805
09-17-2015 04:49 PM
