Very hard to start
Very hard to start
contrary to my user name, i now have a 99 maxima since the 97 had been hit twice (first time by a school bus!). The 99 is giving me a very frustrating issue where it will crank and crank and drain the battery and it won't "catch". Did basic troubleshooting (fuel, spark, compression). Fuel is ok because when it does start and run, which is infrequent, the engine runs fine, although months before this issue the idle "hiccupped" a bit. Spark was inconsistent across coil packs. I replaced two coil packs, cyls 2 and 4 with no improvement. My mechanic thought it was either wiring or ECU. He started by replacing the battery positive connectors with no improvement.
Things I have tried myself:
- coil packs from 95 for cyls 2 and 4
- crankshaft position sensor (got P1335) no improvement
- leak test bank near radiator was 10 to 15% My mechanic doesnt think its a mechanical issue. I didnt do compression test before I towed it to his place.
- my battery is weakening but when fully charged would turn the engine with pretty good speed
- starter is new (replaced after problem started) and gear has 11 teeth.
I'm suspecting the ECU since the wiring had never been touched before the problem surfaced, but I don't want to spend the money yet, just getting ready. This model has the immobilizer. If I get a replacement ecu, how hard is it to reprogram for the keys? Is it just a matter of finding the procedure for reprogramming keys ? i Have seen those somewhere.
When I went to the mechanic with this same hard to start problem, they replaced the MAF sensor, O2 sensor, and Fuel Pressure Regulator to correct the concern. That was $405 without labor. Hope it fixes your problem!
Check the fuse for the fuel pump. I was doing a fuel filter when I had the 99 and I had the fuse out to starve the line and I forgot to put it back in. It would crank forever and then run fine, interestingly enough. Check the fuse and don't rule out a bad fuel pump, or injectors for that matter...
You stated in the things you had tried yourself that your battery was weak but when charged it would crank over fine. have you tried testing your battery under load or testing your altenator aswell? Maybe time for a new battery. Another thing that i noticed wasnt stated is your timing? maybe worth checking that aswell. If it cranks over fine when your battery is fully charged like you had stated i doubt it would be fuel related.
Welcome to the org.
I hope you use this place to save you tons by fixing your own ride.
That's an interesting suggestion that also came up when my mechanic searched his "mechanic's forum" . We couldn't figure out how a deficient ground would happen over time. Will try it if the ignition switch doesn't help
Battery definitely needs replaced but it was tested as having 500 cca so it should b enough to start, which it did a couple times at the shop. If it was a timing issue the engine would run like crap, but it would run fine. Both my mechanic and think it's an electrical issue. We just had not thought abt the ignition switch bc I have been living with the quirky key since it was made. After all anything that moves and makes friction will wear out over time. The wiring I don't think is likely since it's still factory original.
And the winner is ......
Battery negative connector
Took the car back from my mechanic after he told me 120 to install an ignition switch. He figured out how to start it by turning it back to the on position right when it sounded like it was going to catch. I decided to install my optima battery I had lying around in my garage (lol) and the engine turned a lot faster and started with no problem. Then I started it for the second time and I heard something pop and everything turned dark... Turns out the negative connector popped off the battery. Replaced the connector with a new one and voila , no more hard start. Only issue now is the engine needs a rebuild. Hhmph, no end to the problem of driving an old car. Btw, replacing the switch didn't make any difference.
Have not had a good experience buying a used engine or transmission. A quick look at car-part turned up engines for around $300, which is not too big a deal, but you can't tell. The one with 70k miles is about $800 and quite a number of miles from where i am. At least when i rebuild it myself i know i'll be putting in all new seals and stuff.
If your going to put in the time to do that, why not have some fun and do a VQ35 in there?
I wish you the best of luck in your mission, but I still hold ground on swap>rebuild for your money unless you have some future plans for that motor that I didn't know about.
97_GXE
20
09-17-2015 08:12 PM
97_GXE
09-15-2015 06:47 AM
trungg86
09-04-2015 04:58 AM
