CEL on stumbeling and dieing
1995 131K auto
Startsand runs fine for 5 minutes or so them all of a sudden it stumbles and dies. Wont stay running and has zero power.
Codes:
p0130
p0443
p0325
O2
Purge valve
knock sensor
I never saw a o2 or purge valve cause a stall so I unplugged the knock sensor. Now it seems to run fine. I guess this was the knock sensor???
Could that be it? Never dealt with bad knock sensor so I'm unsure what it would cause.
Harm in leaving it unplugged?
Thanks!
Codes:
p0130
p0443
p0325
O2
Purge valve
knock sensor
Thanks!
Could it be a bad ECU, when knock sensor plugged in it causes another issue?
Any of the other current codes O2 or Purge cause this stalling issue.
The purge valve will not cause this. Bad knock sensor may result in loss of power but not the dieing part.
The O2 sensor very well may be the cause. Bank 1 sensor 1.
Are you getting the P1400 on the EGR as well? Vacuum leak at the EGR?
Check for vacuum leaks after the MAF as well
jmlee44
10-02-2022 02:13 PM
maxima297
09-30-2015 03:32 PM
JoshG
51
09-21-2015 10:41 PM
