96 Maxima radiator fans not working
Been reading about my '96 Maxima problem. Radiator assy fans do not move....ever. I have activated both low and high speeds with my trickle charger and junk yard connectors/wires. So the motors seem to work fine. Fuses look good and I swapped the relays with junk yard relays too. No change. I have seen some talk about a temperature sensor that may be causing my dead fans issue also. Any confirmation or advice is greatly appreciated.
How's your coolant temp sensor?
Originally Posted by Quickywd01
(Post 8965181)
Originally Posted by kidscar
(Post 8965184)
I'll look at this tomorrow. Anything to check or just replace and try?
coolant temp sensors are pretty cheap to buy, and easy to put in..id just go to an auto parts store and grab one..if nothing else you eliminated that possibility, and youll have a new ECTS...but i have a feeling changing it will remedy your problem..let us know tho! |
Do they run when you put the A/C on?
Originally Posted by njmaxseltd
(Post 8965254)
Originally Posted by 98maxaholic
(Post 8965194)
Go to a local parts store and pick up the part, keep the receipt just in case you have a gremlin chewing at your wires or something.
Should cost you no more than $150 on the high side and it's very easy to swap the whole fan assembly out yourself. If it works, congratulations. |
The fans will not run with the a/c switch on when the a/c pressure switch senses low refrigerant.
But if you can put power to the fan motors and they run, you certainly don't need to replace them. When you checked the fuses, did you check the fuses under the hood? That's where the radiator fan fuses are. There are 2 fuses, one for the low speed and one for the high speed. In the schematic they are named fuses D and E. The cover has them labeled as RAD FAN 1 and RAD FAN 2. The way it works (with out the a/c on) is then the engine coolant temperature gets to 203º F, the ECU energizes the appropriate relay. So if the temperature sensor registers low, that could do it. You can take a resistance reading of the sensor and compare it with the chart in the FSM or you can get an OBD reader that can display the sensor temperature output. |
(Post 8965328)
But if you can put power to the fan motors and they run, you certainly don't need to replace them. When you checked the fuses, did you check the fuses under the hood? That's where the radiator fan fuses are. There are 2 fuses, one for the low speed and one for the high speed. In the schematic they are named fuses D and E. The cover has them labeled as RAD FAN 1 and RAD FAN 2. The way it works (with out the a/c on) is then the engine coolant temperature gets to 203º F, the ECU energizes the appropriate relay. So if the temperature sensor registers low, that could do it. You can take a resistance reading of the sensor and compare it with the chart in the FSM or you can get an OBD reader that can display the sensor temperature output. I will likely have to take a longer drive to test the fan operation once the coolant temp reaches 203. Would the coolant temp rise to 203 from idling in the driveway? I could give it 20 minutes or so to see if that would do it. Thanks again |
(Post 8965354)
Thanks again Did you check the fuses Dennis mentioned? |
If the fuses are good ...the next thing I'll be doing is applying power to the fans to ensure that they're working (good)....and if they are checking the relays, wiring and CTS (coolant temp sensor) or water temp sensor are working properly!
Originally Posted by CMax03
(Post 8965415)
...the next thing I'll be doing is applying power to the fans to ensure that they're working (good)....and CTS (coolant temp sensor) or water temp sensor are working properly!
(Post 8965435)
Two of your recommendations have already been discussed/checked and have been ruled out. Try and keep up, would ya. ;)
© 2024 MH Sub I, LLC dba Internet Brands
