Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Econ button doesn't work (https://maxima.org/forums/4th-generation-maxima-1995-1999/683465-econ-button-doesnt-work.html)
99black_max Dec 19, 2014 05:01 AM
I have a 99 se the Ac works on auto but not Econ how do I fix that?
CS_AR Dec 19, 2014 05:45 AM
Does the blower still work when the ECON button is selected?
On both of my Infiniti vehicles with auto climate control, the ECON button turns off the A/C compressor -- however the blower continues to circulate air.
njmaxseltd Dec 19, 2014 05:46 AM
Econ does not run the ac compressor. Use it when the temp is below freezing for heat or ventilation only.
dwapenyi Dec 19, 2014 08:42 AM
Your ECON button is working perfectly. It's attempting to give you more fuel economy by forcing the belt driven AC compressor to stay off.
99black_max Dec 19, 2014 03:08 PM
I appreciate the info thanks
max ride 41 Dec 20, 2014 03:06 AM
i forgot all about the econ setting, probably cause i never use it. ;)
dwapenyi Dec 20, 2014 03:22 AM
Yeah, I guess the best way to describe the ECON button is that it does, or tries to do, everything the AUTO mode does, but never lets the AC compressor turn on.
lux97Max Dec 20, 2014 12:40 PM
Yes..I've never knew or even touched the econ button before I read this thread. Used it today, actually worked just as good as using the auto option in 19 degree weather.
Daniel VQ30life Dec 20, 2014 02:48 PM
i always wondered what that button was for lol, makes sense
CS_AR Dec 20, 2014 02:53 PM
Unless the temperature gets over 75 degrees, I run with ECON on most of the time.
lux97Max Dec 20, 2014 03:33 PM
It seems like my gas didn't go down as much/fast compared to when I use the auto option. Givin I was driving like a grandpa tonight.
Daniel VQ30life Dec 20, 2014 04:58 PM
my grandpa only knew brakes and full throttle lol
lux97Max Dec 20, 2014 06:28 PM
Grandpa sounds like someone I would chill with, lol
