Pathfinder Throttle Body Swap
Hi Guys,
I just had a quick question regarding a pathfinder throttle body. I was wondering about installing one. I know an adapter plate is needed to attach the pathfinder throttle body to the stock intake manifold. My question is what about the electrical connectors, throttle cable and the coolant lines. Thanks! |
You can use an adapter plate or I can redrill it for you so no adapter plate is needed. The intake manifold will need to be ported to match the throttle body either way. The TPS is the same, coolant lines aren't necessary to reconnect but you can if you want to, and you use your old throttle cable-however you might need to move the throttle cable bracket or make a new one.
So should I just do an 00VI swap at this point?
Not necessarily. You are still going to have similar issues with the 00vi, in addition to all of the other quirks of installing an 00vi.
© 2024 MH Sub I, LLC dba Internet Brands
