Running Rich Im stumped.
Im running rich on the car, I can smell gas when the car is running at idle. I checked my o2 V and long term fuel trims. I have a DTC for a EGRT fault, nothing else. o2 voltage as follows
Bank1 S01 min- 0 mean 0.3 Max 0.9 Bank2 S02 min 0.1 mean 0.4 Max 0.6 On long term fuel Trim should I be looking at the mean? Bank1 S01 is at mean -1.9 Bank2 SO2 is at mean 1.4 Thanks if someone can halp. |
Many of us have experienced this issue.
The injectors have plastic "pintle caps" which can crack, then leak. The solution is to have the injectors rebuilt. Or buy rebuilt ones on line if we need to get this done in a hurry. The front three injectors are easy to service . The rear ones require removal of the upper intake manifold. Should you need to remove the uim, use the opportunity to replace and service some other items. |
Originally Posted by JvG
(Post 9119621)
I had my original equipment ones rebuilt. The car had close to 200k miles on it at the time. Runs like new.
As fat as I'm aware, there is only one brand. Wait for other members to reply. Injectors are a likely cause of your problem, but not the only one. Have you checked your spark plugs for wetness when the car is cold? Usually the wet one is the cylinder with the bad injector. Plug would look different than the others. For now look at the blue bar near the top of this page. Find the Search. Enter leaking injector. Read some of the previous posts. |
Originally Posted by Maximus909
(Post 9119614)
Im running rich on the car, I can smell gas when the car is running at idle. I checked my o2 V and long term fuel trims. I have a DTC for a EGRT fault, nothing else. o2 voltage as follows Bank1 S01 min- 0 mean 0.3 Max 0.9 Bank2 S02 min 0.1 mean 0.4 Max 0.6 On long term fuel Trim should I be looking at the mean? Bank1 S01 is at mean -1.9 Bank2 SO2 is at mean 1.4 Thanks if someone can halp.
Originally Posted by reallywildstuff
(Post 9119674)
Through what mechanism did you obtain those voltage and trim figures? Thanks
Did you try using MAF cleaner? It's fairly easy and cheap to do, and if it turns out to be all you need, it can save you a lot of time and money.
Originally Posted by thegrindstone99
(Post 9120958)
© 2024 MH Sub I, LLC dba Internet Brands
