Transaxle output shaft seals - manual
Old 02-08-2017, 11:06 AM
Shrout1's Avatar
Trying to ID the part numbers of the seals I need for the transmission when I replace my CV Axles.
My transaxle is model RS5F50A (placard on the firewall); I have a five speed manual.
On the automatic maxima apparently the driver / passenger side seals apparently differ in size...
Any pointers on replacing the CV Axles would also be greatly appreciated! Thanks!!
Shrout1 is offline
Old 02-08-2017, 05:30 PM
komik's Avatar
Originally Posted by CS_AR
For the passenger side, I use National Seal Part # 710124 - The same seal works for VLSD or non-VLSD, Automatic or Manual. That's the only seal that I need to keep in stock for the passenger side. It works on all of my 4th gens.
You can see the double lip inside the seal that really does a good job of keeping the transmission lubricant inside the transmission.
http://www.oreillyauto.com/site/c/de...0071&ppt=C0338
I just installed one earlier this week. No leaks.
Are you working by yourself? I have you have a helper, I can share a trick for how I mount the seal on the passenger side.
Can you snap a picture of where the shaft goes into the transmission? I think I can tell by looking if you have the wrong shaft.
That's the seal I used on the passenger side also. I'm not sure about the driver side. I haven't done that one myself.
komik is offline
Old 02-08-2017, 06:23 PM
JvG
JvG's Avatar
These need to be pressed in evenly on all sides.
I've found that a plastic plumbing coupling for drain pipes work well for this. Find one about the same size as the hard part of the seal. Tap in a little at a time with a hammer. .
JvG is offline
Old 02-08-2017, 07:13 PM
Shrout1's Avatar
Thanks! I actually have that one in my cart on Amazon already Can't quite figure out the driver side and there's no clear indicator anywhere... The FSM seems silent on it as well but perhaps I need to dig a little more.
Shrout1 is offline
Old 02-08-2017, 07:14 PM
Shrout1's Avatar
Thanks! That was another tip I came across today and I'm certainly going to give it a try
Shrout1 is offline
Old 02-09-2017, 12:34 AM
CS_AR's Avatar
For sure.
Here's a thread post below about my homemade "suitable tool" for installing CV seals. The length is most useful on the passenger side where working room is limited. I call this my "KenMoore" CV axle seal tool.
https://maxima.org/forums/4th-genera...ml#post9135915
CS_AR is offline
Old 02-09-2017, 04:37 AM
CS_AR's Avatar
Check National Part 710119.
CS_AR is offline
Old 02-24-2017, 12:00 PM
Shrout1's Avatar
Ok - neither 710124 or 710119 fits the driver's side.
The original seal (which is rather mangled after being removed) is 2.3 Inches around with an inner diameter of 1.5 inches...
I can't find a part number and I can't find it in the haynes or factory service manual... Anyone know what seal this is supposed to be?
Can I find the part number somehow? Call Nissan maybe??
Shrout1 is offline
Old 02-24-2017, 12:11 PM
Shrout1's Avatar
Ok found it in the following post
DennisMik answered the question about two years ago:
710124 = right side (passenger) seal
710118 = left side (driver) seal
The 2 axles have a different size yoke (the piece that goes into the differential).
Right side seal has I.D. of 1.299 inch
Left side seal has I.D. of 1.535 inch
Shrout1 is offline
Old 02-24-2017, 02:34 PM
CS_AR's Avatar
Links to 710119. Hopefully, they work.
Advance Auto
http://shop.advanceautoparts.com/p/n...119&showTitle=
Transmissions
Aichi F50A; 5 Speed
Aichi F50V; 5 Speed
Oreilly
Multiple Applications
5 Speed
- Aichi F50A
5 Speed
- Aichi F50V
CS_AR is offline
