occasional and different O2 sensor codes
First of all, I am a total novice in engine electronics, trying to learn as I go.
I started getting codes 0304 and 0707(KS and rear o2) occasionally a few weeks ago. Each time the CEL came on I just checked the codes and reset it. I know the KS code is a ghost. Lately though, things are different and I am getting 0304 and 0303 instead of 0707. So now it's the FRONT-left o2 instead. Why did the rear o2 stop setting a code? And why did the front-left just start? Should I really replace the front-left o2 when it may just 'fix itself' like the rear did? Normal behavior has been for the CEL to come on once or twice a week, and seemingly more likely after driving harder than usual. |
How many miles does your car have on the odometer and how long have you owned it?
Is your car a Federal or California version? It looks like you might need to consider a set of new O2 sensors. Whenever I buy a used 4th gen usually with mileage over 120,000, I refresh the O2 sensors with a set of new NTK. That keeps away any O2 sensor codes for many years to come. |
You might want to clean the contacts of the oxy sensor fuse. Its located on the right side of the fuse panel by your left knee.
Originally Posted by CS_AR
(Post 9152445)
This is one of those maintenance issues that should be addressed regularly and at the recommended intervals at a minimum. |
© 2024 MH Sub I, LLC dba Internet Brands
