Obd system monitors - 'E' not ready
I had a check engine light problem that was corrected (thank you to all those that helped with that) I then cleared it with a code scanner, all monitors now are ready except the 'E' monitor. I have driven a little over 200 miles in the last 2 days.
What is the 'E' monitor and how can I get it to show ready ?
Also, I'm in NY will my 97 Maxy pass with this one monitor not ready ?
Thank you...
Thank you...
I had this problem during my last smog test. According to the smog guy, it's a common issue he has seen with this car (mine is the same year as yours, so not sure if it's common among all). He ended up just ignoring that issue during the smog test.
I've always had problems with my OBD2 port though. A Scangauge that I purchased would have readout issues on the Max, but work fine on all other cars.
My scanner originally didn't work, I was about to return it when I tried one last time. Then it worked, and has worked ever since.
A garage I brought it to also told me they couldn't get a reading and said there was a problem with my OBD.
Yet I go every year for inspection and they have no problem. It seems that maybe some may have intermittent problems.
Great thank you Maxi ! I took it in this morn and it passed inspection.
Though after more than 300 miles the EGR monitor is still not ready. What do you have to do to get this one to reset !
Don't ask me how I know !
