CT DEK swap help
CT DEK swap help
Have recently swapped 96 Max with 01 DEK. Cranks ALL day, no start. Sprayed starting fluid and ran like crap for about 10 seconds then died. HAS new fuel Walboro 255, 350Z spliced injectors, new OEM CPK and CPS. Cleaned ALL grounds, new plugs, new fuel filter. Retraced every wire back to ECU. I've searched everywhere with no luck. Is there someone out there who can help? $ on hand to help me figure this out. Way too many details to post, shoot me a PM and will explain. Not new to 4th gens AT ALL (Actually my 6th one but 1st DEK Swap) I have another Max w/160k I can swap the 00vi into but wanted to try to get this running because motor has 47k. Thanks in advance
It ran beautifully then one day...no start, went through everything finally swapped fuel pump no go, changed fuel filters still no go. No codes, I will try cranking again later and rescan to see if anything pops up. Its weird
Whats up man? Thanks for your response. These grounds are so new and clean you can eat off of them lol I disconnected battery so I'm installing battery again tonight, gonna crank and check for codes. Any input helps!
