Spedometer and cruise control dont work
Hi every one I have a 97 gxe two things that I can't get to work is the cruise control and my switch on the steering wheel is bad I tested it. Where should I get another one from a dealer or online. The second issue I have is the speedometer is iffy it works but not all the time I replaced the vechicle speed sensor it does the same thing now I have not tested the new one yet I will try to shortly is there something else that could be making my speedometer not work all the time. Thank you.
you can get the cruise switch at a dealer, I would go new on speedo head and switch or take a risk with a used part online.
Thanks for your help but the dealer said the cruise control switch is discontinued and buy they did point me to a person that can work on my speedometer my question is that I'll drive it to the store it works driving home it won't work till about 50 mph is that the speedometer gear on the instrument cluster
thank you
thank you
thank you
thank you
Yes, the instrument cluster is your issue. Just replace the speedo head and you’re good to go.
I had the same issue with my 97. Got a code for speed sensor, a friend of mine who works for Nissan told me it’s a common issue for the speedo head in the gauge cluster to go. So I bought a new one from Nissan, they set my mileage and I replaced it easily.
i just bought a used speedo cluster that had close to my mileage, drove it around the block and it worked fine. $160.00 like 8 years ago, that was actually a recall on our car back in the 90's.
I didn’t remember a recall for speedo head but I do remember the alternator recall.
I'm thinking it's the Vehicle Speed Sensor (VSS).
https://maxima.org/forums/4th-genera...peedo-cel.html
I don't believe ptatohed talked about it, but I know his cruise control failed to work when the VSS failed to work.
