Bosch 13783 O2 Sensor question (P0136)
Can anyone confirm the number of wires being 3?
P0136 Bank 1 Sensor 2.
Searching the forum tells me that it is supposed to be 4 wires.
Bosch shows 13783 Downstream sensor as 3 wires.
Am I missing something?
Amazon.com search tells me it doesn't fit 95 Maxima.
Bosch shows it to be exact fit.
Going to pull it out in the morning to check before ordering the sensor.
If 13783 isn't right, what should I get?
The downstream oxygen sensor in the 95-96 Maximas has 3 wires
The 97-99 downstream has 4 wires
If you have a 95 and ordered the 3-wire sensor, then you have the correct part
Amazon's fitment guide isn't the most accurate. If Bosch says it's ok and you confirmed it on their site, it should be ok.
One more thing you should know: the nut is 14mm.
The Bosch sensor will most likely be a reboxed NTK 24024, which is the actual OE sensor. There's also the Denso 234-3123. Get whichever has hte best price.
soybeanz
02-19-2007 12:30 PM
Xtr3m3X
02-13-2007 07:37 AM
Colossus
09-24-2005 01:17 PM
