Any idea what this noise is?
So tonight we put on a shorter belt to bypass the failing a/c compressor clutch. When I started it back up the a/c noise was, obviously, gone, but now there's another noise...
Any idea what that could be? Idler pulley or power steering pump?
https://www.youtube.com/watch?v=-30umR1UBsA
Any less than that results in belt sqeal, while any more causes unhappy bearings in the tensioner and alternator.
Wow listening to this clip sounds like the machine that you use at a butchers meat shop. I think it could be a ps pump pulley or a harmonic pulley. Is it wobbling on the crank or the ps pulley. I just bought me a stethoscope. I am experiencing a similar problem but worse more like an screeching idler pulley or a alternator bearing. I got the scope so i will narrow it out with it.
If the noise you are referring to is the occasional rattling sound, than it might be the idle pulley top nut hitting its own bracket. For me, I did not have the top nuts flange resting against the the bracket and it would rattling occasionally at cold start. In the maintenance section of the service manual it actually gives you a range of torque specs to tension the oem belt. Once you are within that range than you tighten the pulleys nut to secure it.
I'm not sure what part in there could be loose or rattling though, but it definitely sounds like something is moving around. Also when I put pressure in the idle pulley nut and the top adjustment nut the sound didn't change which led me to believe it wasn't them.
JSutter
08-16-2003 02:04 AM
Craig Mack
03-14-2003 07:40 AM
TitleistPrto
02-06-2003 06:53 PM
